Portable jump starter
toddhunter64
Ukiah, Ca
Maverick XLT
I’ve noticed that the portable jump starters I see advertised look like the cables aren’t long enough to reach the negative ground bolt and the positive battery post. Is this true, or just an optical illusion ?? I’d like to carry one with me just in case, or possibly help someone out of a jam, but definitely want to be able to jump my own vehicle as well. Anyone have experience with these ?? There are dozens to choose from, but all of the cables look to be about the same length. Thanks in advance
TrailMaster
Western Colorado
Optical illusion. I have two, the cables on both reach the positive and negative terminals easily.
toddhunter64
Ukiah, Ca
Maverick XLT
Ok, I get that they will reach the actual positive and negative terminals, but I thought I read somewhere that you weren’t supposed to use the actual negative terminal on the battery. I thought you were supposed to use the negative ground bolt that is attached to the frame. It’s located to the left of the battery. Maybe that’s what is supposed to be used when you use actual battery jumper cables. 🤔🤔
Ozarkbeard
On the Hybrid, jump it under the hood, not under the back seat. My jump box reaches the positive post under the hood on the driver's side, and a nearby bolt on the truck body for the negative. But I haven't had to use it on my Maverick. I have used it on other vehicles though - the latest one was a friend's Lincoln Town Car. Worked great.
https://www.amazon.com/gp/product/B015TKUPIC
RedRider
Kitchener, Ontario, Canada
The CAT jumpstart box that Costco sells has only 8" cables, which makes it impossible to actually use under the hood or in the cab. Its a really bad design.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
On a hybrid, hook the red cable to the under hood positive post and the black cable to shiny nut or bolt.
That is a VERY simplified instruction, but as long as the shiny spot is bare metal, it should work. Most jump boxes have lights to tell you if your hooked correctly. Just don't hook up to anything that is orange. 12 volts and 56 volts do not play nice together.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
You mean 400V instead of 56V, right?
Looks like you are correct. Don't know where the 56 volt came from, but I checked and 400+ seems to be the right answer.
Thanks.
Neils Bohr
Neils
Ontario
Ford Maverick XLT
Did you ever get a portable booster and were the cables long enough? I just ordered one but the cables look too short to me too.
Neils,
I'm sure your Astro AI will be fine.
Here are the shortest leads from one of my old **Schumacher jump packs.
They are 18" long.
Ford Maverick Portable jump starter IMG_20251211_100452
Ford Maverick Portable jump starter IMG20251210200120
And here are the leads "connected" to the proper connection points to jump start a hybrid Maverick.
I hooked it up to the negative stud but I did not want to hook it up to the positive one, so I clamped it to a wire that was actually further away than the positive stud. They are nowhere near pulled tight.
Ford Maverick Portable jump starter IMG20251210200100
**Never buy a Schumacher jump pack.
Neils Bohr
Neils
Ontario
Ford Maverick XLT
🤔 hmm let me see
says they should be about 18 inches span, but most of them look like 12 inch span in the pics. Seems the Noco ones are long enough. I ordered an Astro AI so I'll see if it has long enough cables when I get it.
Ranko Kohime
Ranko
2025 Maverick XLT
I'll do a +1 for NOCO, I bought the full size one for semi-trucks, (Edit: the 4250A) and it overspun the starter on a Buick LeSabre with the Series II V6.
A tip to make your jump boxes last longer: if they have USB ports, use them. Run them down, and charge them at least once a week. Lithium batteries don't like to sit.
Suzukiridr14
Frank
Sarasota Florida
I made up a small (about 24") extension chord with alligator clips on both ends to use if I need it to reach the ground stud on the drivers side inner fender on my hybrid Maverick. Never needed to use it, my truck always starts. Also check with Amazon, you can get a 3000A jump box for around $30, that's equal to a NOCO which costs over $100.
FischAutoTechGarten
Peter
To date, I've jumped at least 4 different vehicles with the NOCO 40 portable jumper that I bought with my Ford points. Two of those vehicles were parked in such a fashion that it would have been nearly impossible to reach with my truck and traditional jumper cables. The NOCO is really a nice piece of kit to have. Three of four vehicles that I jumped went on to buy the NOCO. The one that didn't is a cheap neighbor.
Backin15
Frozen Minnesota
2025 Maverick XLT
I received a Noco GB40 last Christmas, haven't had to use it other than to start my lawn mower once but it is nice to have. The leads are not very long, but long enough.
You are correct that it is recommended not to connect the negative to the battery but to a good ground, the main reason being that it could create a spark that could ignite flammable gasses.
Ford Maverick Portable jump starter 20251211_091748
