Phone connectivity issue via the USB
JoeFast
Salem, Or
2022 Ford Maverick AWD
Hi all, I have a AWD XLT. Of course it doesn't have the SYNC 3. I'm having issues with phone connectivity via the USB. My phone connection will turn off sporadically, the phone will take up to 15 to 20 seconds to connect when it does connecte and the "system" doesn't recognize the connection if the phone is connected when the truck is turned off then on again. Thanks for your help!! Joe
brdavis1
Dodge dakota
Speaking of phones mine works fine so far , I phone w/ sync3 , but was wondering , can I get split screen between radio & gps map ?
OCasey
Sean
2022 Mav XLT Cactus Gray
Have you tried a different high quality cable? One of the easiest things to try and correct this. I had the same issues, it was a bad cable.
Gullzway
OK
1968 Ford Mustang Fastback
No, you either use Carplay screen or Ford radio. You can select Radio screen on the instrument cluster for limited Song info.
Bushmaster2000
Jones
WA
F150
Anyone know if the type A usb port is only for charging, or can you put a flash drive in there loaded with MP3 music and play off the flash drive? I don't like playing off the phone as it gets interrupted every time there's a text or call or who knows what else notifications. I'd just like to load up a usb drive with music and plug it in somehow.
Yes. I have my AAWireless connected to the USB-C and a Sandisk Cruzer Fit with audio files in the USB-A port.
Bushmaster2000
Jones
WA
F150
Excellent news. I've give that a try today. Thanks!
WannaMav
Hawaii
2022 Maverick hybrid
Both the front panel USB A and the USB C ports closest to the driver provide data transfer.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Use a different USB cable as some become intermittent from being bent near the connector going into the phone.
This was a problem for me and a new cable fixed it.
I now place my plugged in phone to the right of where they suggest so not to bend the cable near the connector.
WannaMav
Hawaii
Just to add as a general observation, USB cables are not something to skimp on when it comes to their cost. There are many very good ones but also a plethora of really crappy ones.
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
Me too. And the audio quality off of the USB is so much better than bluetooth audio or the radio!
New2AZ
Scottsdale, AZ
2019 Civic EX Hatchback
Can't split-screen built in radio/SXM with Car Play as far as I can tell. I can keep listening to the built-in XM and use Carplay at once, but you have to use your phone aps if you want to split screen them.
Bushmaster2000
Jones
WA
F150
Tried my USB loaded with MP3's from my old car in the USB A port in the Mav... worked like a champ! Thanks for the tip!
