PAC AmpPRO no longer the answer! 2025 B&O
newagecritter
Virginia
2025 Maverick
So I was trying to hook this thing up to the factory speakers. Ford has changed the data connection now. The PAC works with a micro usb but that is not what my truck has! Currently the only way to add aftermarket full system is hi level input. I verified it with a local shop who did some research. There is a T harness available from a few companies. Good news is the T harness is boatloads more cost effective.
Mavelous2023
Me
NorCal
2023 Hybrid
This is for 2023s too or only later models? Looking to add woofer and get some low end and more range from existing. The only posts I’ve seen are to replace speakers and add an amp.
newagecritter
newagecritter
Virginia
2025 Maverick
My best research shows it’ll work for everything except the 2025.
newagecritter
newagecritter
Virginia
2025 Maverick
The T-harness I bought and confirmed it works is PAC APH-FD02. You must keep the B&O amp connected and you have to shave the guide off the clip. It’s super easy and does not make it irreversible. I’ll be doing some wire cleanup tomorrow and I’ll post some images.
Aaron F
Aaron
Sterling Heights, MI
2023 Maverick Lariat Lux w/ 4k and BAP / 2025 Maverick AWD Hybrid Lariat w/ 4k
I have the AmpPro in my 23 with B&O. It works for sure. The only odd thing I find after the sound upgrade (didn't pay attention enough if it was there before), is that Android auto, bluetooth, or just Samsung phone plugged in via USB loses the equivalent of about 4-5 notches on the volume control vs FM radio or an apple phone plugged in via USB.
That sounds like the normal difference in gain between radio and Android Auto, really. I normally have to be at about 9-11 for radio to be at the same level as 15 for AA.
newagecritter
newagecritter
Virginia
2025 Maverick
It’s definitely only a problem for MY25. The audio in has changed from 24.
