Outgoing/Incoming calls on Carplay
JimParker256
Cedar Park, TX
Did you ever figure this out? I have the same issue. CarPlay works great except for incoming calls. All the advice I can find is for when it's not working at all.
Ignoring the CarPlay for just a minute... You should be using Bluetooth to connect your phone to your truck for calls. Get that working BEFORE you even plug in to CarPlay. If you do it that way, it should work just fine. (And yes, you'll have two connections between your vehicle and your iPhone - one BT for calling, and "cable" (wired) for CarPlay functions.
PS - My Sync system has been updated to Sync 3.4.22251, which might make a difference. Hope that helps.
caldwellheath
Heath
xlt 2023 maverick
Has anyone else had an issue with incoming calls not working on CarPlay? The call comes through, I answer, but I can’t hear the caller and they can’t hear me. Outgoing calls are unaffected.
I am having the same issue with my 2023. Seems when I plug in the usb it drops the Bluetooth connection. Most incoming calls don’t get transferred to the truck speakers/mic. I have to pick up the phone. The call does come through it’s just most times only through the phone and not through hands free.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
Yes - but once you make an outgoing call, incoming calls work.
xlt-doug
Ed
New York
Maverick (soon) Escape (current)
Has anyone figured out a fix for this issue. I have to disconnect and reconnect to CarPlay in order to answer calls.
xlt-doug
Ed
New York
My connection problem has been solved. Switched over from Verizon to AT&T and now have no issues answering calls while plugged into car play. Not sure why but Verizon was definitely causing the issue for me
Clarkdonbran
Clarkdonbran
Interesting. I have xfinity which uses Verizon towers. I had AT&T for a while, but it was too expensive.
xlt-doug
Ed
New York
[/QUOTE
Yeah it’s weird that it works now. Was a pain unplugging every time
Toto1997
Jerod
nIvLFRewlT7_SwE__4pLFru#$-I
Hey! I can take a closer look into your Carplay issues. Can you please send us a direct message with your VIN and the dealership name/location?
FoMoCo- are you still taking requests? Been trying to figure this out for almost a year and a half. Have tried ALL. THE. THINGS. No luck.
BunsSauce
Jason
FL
24 XLT Hybrid
no help here other than to say that Ford no longer monitors this message board. There was a post about 6 months ago saying they would be going inactive.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
You are responding to a “BOT”, don’t waste your time!
