I am shocked to hear that. Not even a little curious?And have not run my gt500.
Brother....I REALLY hope your not going to try and run that 2.3 off that 8 speed tranny in the Maverick. I've had a Livernois 93 tuned 2019 Ranger and there is ABSOLUTELY NO WAY that Maverick tranny can take the low end torque of that 2.3 ecobeast. I know you are more than knowledgeable about the engine swap so I'm curious what you will do about the transmission......10 speed swap of the 8 speed maybe? Can't wait to see how this turns out. I know a lot about the capabilities of the 2.3. AWESOME platform......you can safely take it to 350 hp but it seems the folks that start to get above 400 hp start getting the "rod off light". Keep us posted!105k on OE, modded at 60k; cvf downpipe, 3 in exhaust, no muff, cvf intercooler, livernois 93 tune, sb intake, both side catch cans, underdrive wp pulley, optimal yellow top, booma spacers(for methanol, not yet added) lowered.
2.3 will be swapped in bone stock to drive while goin thru the 2.0
I will use with the 2.3 head and turbo with a built bottom 2.3 rotating assembly
Am am but I have toe young boys and my free time is spent at the road course But yes I’d like to know cause I’m at 1048whp so it should be fastI am shocked to hear that. Not even a little curious?
that's definitely not going to happen because the 10 speed is only fitted to longitudinal mounted engines.10 speed swap of the 8 speed maybe
my comment before about the tcm are in regards to keeping the Maverick ECU so that you keep all the things it does including infotainment, drive modes, telematics (Fordpass is useful) and even climate control.Could you go with a manual tranny? How could you let all of the computers know that it is an manual Tranny?![]()
yes, they are rolling computers. if it's a factory option it probably can be done relatively easily but since it isn't you either give up major functionality (fine for a racecar but not daily driver) or you turn it into whatever factory vehicle has that powertrain.I swapped a AOD for a manual on a 92 foxbody, and I think that would be a lot easier than anything today. Added the AL9 computer and some minor wiring changes, poof it was done (added the shifter hump as well). I figured it would be quite an undertaking for these Modern chariots.
Just the 2.3 nope.I wonder what gremlins are going to show up when they swap in the 2.3,,,Just saying
yep it's all the stuff mentioned in the first post.Just the 2.3 nope.
They are very interchangeable back and forth. Longer stroke and different block. But they play well together.
