Dimensions wise THIS ONE will fit, 3 1/2 inches deep at the top and 7 inches deep at the bottom…. With any of these you’ll likely need to cut off the factory “amp rack”… the problem with this one is the width, it’s 27”…. The restriction by options/model is that you’ll need the entire space from the passenger side blue trim to the middle blue trim covering the seat belt assembly.Tell us MORE about the pre fab boxes you mentioned, and what variables behind the seat you are referring to.....tax refund coming!!![]()
Was playing with custom box designs instead of going this route, but ported you won’t have enough space, and the passive radiator basically gives you ported without having to provide the “ported” cubic footage the sub needs to hit the frequencies I want. What do I mean? I don’t want trunk rattling bass, I want to reproduce certain low end frequencies while having the gains almost as low as possible.
The other is a question mark as to the depth dimensions…. Kicker 46TL7T It’s 5” at the top and 8” at the bottom and it may angle out too fit to be able to close the seat, so it would likely either take an edit of this box or a custom enclosure such as this one (ignore the round sub, this is for a square solo baric)
have been compiling a list of boxes that would fit back there, and was going to do a “Where’s the Bass” thread, but I wanted to test some of them first
a few other 12s that have a low enough mounting depth and would work in a similar enclosure to the above are:
https://www.crutchfield.com/p_109CL1200/JBL-Club-WS1200.html?tp=111
And
https://www.crutchfield.com/p_130TSA30LS/Pioneer-TS-A3000LS4.html?tp=111
there’s some other 12s from like JL, fosgate etcthat would work in similar, but the JL is a lot more $
oh and how could I forgetTHIS ONE FROM MEMPHIS that includes the amp. I can’t find the exact specs on top depth, but bottom depth is 7.5” which makes me believe it would work especially because of the placement of the sub (you have the deepest area to work with on that part of the seat as far as seat back support bars, etc)
