Edit: I put this in the wrong subforum sorry! Should be in "Mechanical Maintenance: Break-In / Oils & Fluids / Consumables / Servicing"
So I have a Blackstone oil kit and a manual oil siphon pump. My plan was to drive over 30 min to get things up to temp and siphon 200-300 milliliters of oil from the oil cap. I'm currently at 400 mi with varying drive situations City, highway, country roads with four-way stops. feel like I've gotten everything I need to do beyond romping the gas pedal which I don't plan on doing till the oil analysis comes back. then at A thousand miles I'm going to change the oil. I've heard that depending on your driving this eco-Boost can be broken in in under 500 MI.
Does it matter if you siphon the oil from the top vs taking a sample from the drain plug? Id imagine at full operating temp and some driving the contaminates should be well enough circulated to take from either end.
2025 2.0l ecoboost
2025 2.0l ecoboost
