OIL CHANGE PRICE
crgator
Ron
Space Coast, Florida
2023 Maverick XLT
I just checked the manual. Here's what it says for the hybrid. Motorcraft® SAE 0W-20 Motor Oil XO-0W20-QFS.
For the 2.0 EB, Motorcraft® SAE 5W-30 Motor Oil XO-5W30-Q1SP, XO-5W30-Q1FS
IconicSilverMaverick
Maverick XL
I had a bad experience paying to get an oil change on another vehicle, so I do it myself now.
Tech forgot to screw the filter on and started the motor. Sent the filter flying and oil went everywhere. They used brake cleaner to clean the mess, and destroyed the clear plastic that covers the headlight bulbs with the solvent in the process.
Happy to do it myself now.
Kind of like when the barber gave me a Forrest Gump haircut when I asked for a high and tight/fade. Learned how to do it myself.
Not hard to learn and not a tough job to perform. Especially after you install your 2" lift.
jsus
2022 Ford Escape Hybrid AWD
Old Ford Guy
Rod
Northeast Ohio
2024 Maverick Hybrid Lariat ; 2016 Linc Navigator
Just got a quote at my local California dealer for LOF change. $131 for Full Synthetic.
Tire rotation: $29.95
Yikes!! thats pretty pricey compared to what i usually see in my part of the country.
Old Ford Guy
Rod
Northeast Ohio
I thought the hybrid was supposed to use full synthetic oil only. (?)
so did i.
my service advisor that i trust was adamant that the synthetic blend as opposed to full synthetic was the 'official' Ford recommended replacement oil. maybe it was, i dont honestly know at this point.
he tried to talk me out of the early oil change (done at 1750mi) as unnecessary so soon. i didnt care. i wanted that 'break in oil' out of there. i am sure that there are some benefits to be had from the full synthetic. but my oil will never be in the engine longer than 12mo or 10,000mi so what difference does it make? maybe if i were using a full syn i could forget about the 12mo thing and just change the oil based on miles (15,000 vs 10,000mi interval) or oil life monitor readings?
it may be true that the full syn doesnt break down and lose its effectiveness at the same rate over time/miles as other blends but im not sure the 'juice is worth the squeeze' for my usage model. i am not that guy who only changes oil based on mileage. yes, full synthetic would probably be a better choice under some circumstances. but that synthetic blend wont be in the engine long enough to degrade over time to the point where i would regret not using the full synthetic IMHO.
GPSMan
Many
Cleveland Ohio
$110.98 Full Synthetic (Hybrid)
$88.98 Syth Blend ( EcoBoost )
$56.98 Conventional ( Not recommended )
Ford Maverick OIL CHANGE PRICE 7B590479-7A05-430D-A822-58EB0B8B5FE2
Fibrepunk
2023 Ford Maverick XLT Hybrid
Cleveland Ohio
You go get your oil change at Jiffy Lube, you are just asking for trouble.
Joe Mac
Marin
Shelby GT350 F250 Super Duty
I did my first oil change at 1500 miles. This was done at the dealer for $92.00.
I did'nt think it was to expensive.
GPSMan
Many
Eco not as expensive as a hybrid if you didn't get full synthetic.
Old Ford Guy
Rod
Northeast Ohio
there is a ad from a local Ford dealer (Elyria Ford in Elyria, Ohio) in the local newspaper in my town offering the 'works' oil change pkg which includes a oil drain & refill wth the OEM recommended oil filter & oil; vehicle inspection; tire rotation and various fluid top offs for $59.99 n todays newspaper. why are folks paying so much more for this service continues to confound me. i thought it might be a regional thing but i have seen numerous posts from around my area with wild price discrepancies, so my advice is buyer beware.
B2000
midwest
B2000
Got my first change today- only have about 1200 miles but I don't like leaving that first oil in there too long. Guy said they use a blend but I thought the manual said full synthetic so I asked for that. He said $110 which is about what my Infiniti is for full synthetic but turns out that price is for 5 quarts. Magically the price turned into $147 including tax, the extra half a quart, and $17 for "shop supplies."
Asked about the auto shut off which does not seem to work even when the air is off but then sometimes it will work for a day. "The guy that can diagnose that" is not available for a month. I think I will miss the Infiniti service.
NJBob
New Jersey
No. Unless you spring for the synthetic blinker fluid and the unobtanium muffler bearing upgrade.
I recall a guy telling a coworker. His car had a bad demonstrating shaft. I was a kid knew it was bs but the guy fell for it.
Moon
Ronnie
Georgia
Dodge Ram. Toyota Rav4
Is it really over $100 for a dealership oil change!!??
My dealer said $90-$100. Walmart Auto had it for $48.88 full synthetic most major brands.
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
That would be for synthetic blend only. If you want / require full synthetic (like hybrid), the "works" oil change will be more.
