New tires today: BF Goodrich Advantage
Tim d
Alpena
Ram
At 35k original miles with probably a few miles more but it’s time for tires upgrade. Out with the old and in with the new. BF Goodrich Advantage
Our 23 has similar miles, at a recent oil change the dealer told us we need new tires bad. I thought the factory continentals were rated for 50k?
Like posted fuel economy figures.
Tire mileage is Comparative, not absolute:
A tire's mileage rating is a relative comparison of its tread life, part of the Uniform Tire Quality Grading (UTQG) system, found on the tire's sidewall.
A higher treadwear number indicates a longer expected lifespan, but it's not a guarantee of specific mileage because the actual life of a tire depends on factors like driving habits, road conditions, and tire maintenance.
A tire with a rating of 400 is expected to last twice as long as a tire with a 200 rating under the same conditions, but the number doesn't represent a precise mileage figure.
Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
The factory tires don't have as much tread as ones bought from a tire dealer. Ford contracts out certain manufacturer brand tires. I replaced my Continentials the day after I picked up my vehicle. I could'nt belive how light and flexible the sidewalls were. Put Firestone Destination ones for my winter ones.
Tim d
Alpena
Ram
Gotcha, we are happy with the continentals here in northern michigan. Will probably replace in a year or so when closer to 50k.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Continentals from factory are a decent tire...with that said, the BFG's are a good, solid choice for daily use.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Just swapped my 225/55/19 Goodyear Territory HT for 235/55/19 Falken Wildpeak AT Trail. While efficiency is going to take a big hit they have made the truck feel much more planted and improved the ride quality significantly.
Timothyd
Let us know if those tires give you a better ride.
Marty
2026 Ford Maverick Tremor
Every time I switched from all season to all terrain I lost 1 to 2 mpg at most. But I gained bucket loads of traction and control in the rain and snow.
On my roads a mid life Michelin all season with 6-7 32’nds tread depth left hydroplanes at an annoying level when I hit water.
All my All Terrains
Yoko Geolandars and Faulkin Rubitreks with as little as 5-6 32’nds of tread do not hydroplane one bit under the same conditions.
Plus the AT’s start out at 12-13 32’nds not
10 32’nds.
My stock Michelins look like they belong on an economy car not a truck.
The look of AT’s add a good dose of Badassery to any pickup truck.
And since I can be a bit of a haul asser/lead foot I can ease up on my throttle a bit and easily compensate making that 1-2 mpg loss with the AT’s pretty much stay under 1 mpg making that a non issue.
Oh and 710-oil dude, I had to drop one psi when I went from 225 to 235 to maintain even tread wear per my tire depth gage.
Just sayin’
Cancunbadlands
Cancun
Cancun
Getting ready for winter
710-oil-614
Cal
All my All Terrains
10 32’nds.
Just sayin’
I always run a few psi low. I expected the MPG hit but they make such a massive difference.
ScottyC
Central NY
@710-oil-614 Just swapped my 225/55/19 Goodyear Territory HT for 235/55/19 Falken Wildpeak AT Trail. While efficiency is going to take a big hit they have made the truck feel much more planted and improved the ride quality significantly.
@710-oil-614 Did you stay with an Extra Load tire? Curious if you did....
710-oil-614
Cal
Good question.
So the 235/55/19 in the Wildpeak Trails only comes in a XL load.
The 225/55/19 only come in the SL load.
The 235s were only 1.5 lbs heavier which pushed me to the 235s and XL load rating.
While I will rue the loss of efficiency it's something I knew was going to occur and I was ready for my Mav to be a little more truckish. I can't replace the AWD with the Advanced AWD system from the Tremor but I can improve the Hybrid AWD to at least be a F(au)X4
