Need someone to verify these will work with steelies
jdium
oregon
2025 Lariat
I picked up a set of takeoff steelies with TPS for $150, but they did not come with center caps or lug nuts. From what I understand, the factory Lariat lugs I have won’t work?
the question is will these
Ford Maverick Need someone to verify these will work with steelies IMG_7219
Work with this 3D printed center cap:
Ford Maverick Need someone to verify these will work with steelies IMG_7220
Here’s the links:
https://a.co/d/31pRfY4
https://a.co/d/8HWDbrT
I’ve got an idea of a concept for winter rims that aren’t just the same old silver steelies.
Hot Runr Guy
West Chicago, IL
Unlike the OEM center caps, these seem to have "bumps" in the recesses to engage the lug nuts, this image I found shows the OEM steelie lug nuts, the lug nuts you show probably will not retain them.
HRG
Ford Maverick Need someone to verify these will work with steelies il_1588xN.5627822586_g1pr
jdium
oregon
2025 Lariat
Thanks. So I’m looking for lugs with the 30mm lip. I was hoping to find something besides the open ended OEM acorns. Do you or anybody happen to know the required thread depth needed if buying a closed lug?
I’ve found chrome and black close ended lugs with 30° seating angle and 30mm OD. Was hoping to find anodized blue but so far no luck.
Maverick123
Waiting
The lug nuts' description mentions acorn seat (which would be wrong for a Maverick) while the drawing shows them being cone seat. So, one or the other is wrong.
And why does the center cap mention 'only compatible with 17" wheels'? The hub area on steelies should be identical regardless of wheel diameter
It looks like there isn't enough accurate info provided in the descriptions. It might work but you'll have to order the parts in order to be sure
jdium
oregon
2025 Lariat
No idea why they specify 17 inch rims only. The plan was to buy 1 and test fit.
I’m so lost on whether or not I need acorn (radius base) nut or a conical angled seat. Even google AI states “in summary, for your Ford Maverick steel rims, you'll need M14x1.5mm lug nuts with a 60-degree conical or acorn seat. “
jdium
oregon
2025 Lariat
Conical. People need to stop blindly trusting what AI spews out,,,,,,
HRG
People need to understand what “blindly trusting” means.
If I blindly trusted I wouldn’t be questioning the answer given…
Thank you for the information either way…
Allen King Jr
Allen
Springfield Missouri
2019 Grand Caravan GT, 2006 Mercury Mariner
You can use the same lug nut as the 2017 Ford Edge on your truck, the Ford catalog crosses the OEM number to both vehicles, hope this helps.
