My Tremor won't into neutral unless I hit the L button
Tremor1942
Phil
Pennsylvania
2023 Maverick Tremor
My tremor will not go into neutral unless I hit the L button. Figured this out at a car wash today.......is this normal? To be clear even though the prompt says to Stay in neutral I had to hit the L button to engage. I also have an Xlt Mav front wheel drive eco boost and do not get this prompt.
Ford Maverick My Tremor won't into neutral unless I hit the L button PXL_20240127_201018627
dalola
Retired
SE Ohio 🇺🇸
It's not to "go" to neutral, it's to "stay" in N if you get out of the truck. It will stay in N without hitting L if you stay in the truck. I get the same message.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I've never been through a car wash in my life. I assume you stay in your car (truck), in N, with the engine off?
Tremor1942
Phil
Pennsylvania
Tried it on a hill today. The truck will not roll unless I hit L. After putting in neutral
ABTremor
NC
2023 Tremor
When you turn off the key the truck automatically goes into park so please don't do that in a car wash, it might end badly.
Maverickman74
Shane
Maui HI
Thats a fair safety feature I suppose. Aside from a breakdown or up on jackstands scenario I dont have alot of reason to be outside of the vehicle while its in neutral though. Still it does allow it if you press L. Im sure there is a modern car somewhere that wont allow that with out hooking up a computer to it.
ABTremor
NC
2023 Tremor
My '23 Tremor doesn't act like that. If I shift from drive or reverse into neutral it rolls down my driveway as I expect it to. Is yours a '24?
Maverickman74
Shane
Maui HI
Engine stays on during the autowash.
Maverickman74
Shane
Maui HI
But what happens when you bail out? Thats OPs scenario.
So if you want to use your truck as a battering ram while you tuck and roll to go sneak around and flank the bad guy, you have to push the L button first.
rclee
Rob
Dayton Ohio
If you are going to ride in the car for the carwash, you should only have to put it in Neutral. If it is one of those carwashes that you need to get out and let it "ride" through the wash without you in it, I would say you need to hit the "L"
ABTremor
NC
2023 Tremor
Battering ram mode would be locking the dif in AWD and putting a brick on the throttle, bungy cord from steering wheel to brake pedal to keep 'er going kinda straight... then tuck and roll 😋
Loose all yer momentum if you put it in neutral...
dalola
Retired
SE Ohio 🇺🇸
If so, you have a malfunction of some type. A warranty claim may be in order.
Tremor1942
Phil
Pennsylvania
Mine is a 23. looks like i need to take it to the dealership
Maverickman74
Shane
Maui HI
Thats true, guess I was thinking about how I used to ghost ride my huffy back in the day lol.
Hot Runr Guy
West Chicago, IL
Do you have the Auto (brake) Hold system on? Is the icon shown below illuminated on your dash?
HRG
Ford Maverick My Tremor won't into neutral unless I hit the L button auto hold
