Must Do Maverick Upgrades
kmish203
Jeep Renegade
Any noticeable MPG drop with the larger tires?
waxwins16
waxwins16
Brennon
Georgia
Ford Maverick Lariat
Your taillights would fail inspection in Virginia. They must be red and NO tint of any kind. People here think oh well it failed inspection but that gets logged into the database and why which is monitored by insurance. I know someone who lost their insurance for failed inspections due to the lift they put on a truck.
The tail lights aren't dimmed I used ZEP a chemical degreaser. It's a super easy process for 15 dollars. It does not affect the visibility at all. It's the same thing as the blackout package.
stevj
Stev
Pacific Northwest
2026 Hybrid Maverick
You are incorrect.
You have removed the reflective surface inside the tail lamp housing with the ZEP treatment, so now your brake and turn signal lamps' intensity, and therefore visibility, is effectively reduced.
You have indeed created a situation for yourself.
waxwins16
waxwins16
Brennon
Georgia
Respectfully Steve you are incorrect.
Aleks
Aleks
West Coast
Those look great! If it doesn't remove the chrome coating from the actual brake bulb reflectors, then thats a solid trick!
You gotta split the headlights apart and zep the internal headlight surrounds!
waxwins16
waxwins16
Brennon
Georgia
That really sucks. Insurance definitely always seems to find a way to screw people over. Knock on wood, I have done plenty of aftermarket stuff to trucks in the past and never have ran into this issue with Geico Military.
waxwins16
waxwins16
Brennon
Georgia
No, insurance doesn't reward people who don't or can't read. They insured it as built not as modified. I have only had glass and hail claims in 50 years of driving. So I personally have not had a collision claim denied.
Seems like most mods are covered as long as you notify your insurance.
Ford Maverick Must Do Maverick Upgrades Screenshot_20250509-151238~2
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
That is a sharp looking Maverick. You have good taste, didn't over do-it with the exterior mods. Are your window visors Maxzina or EGR?
waxwins16
waxwins16
Brennon
Georgia
I appreciate it! I'm not sure what they are, I purchased the truck pre owned and they were on it already.
mtneerdan1987
Daniel
Summersville, WV
2024 Ford Maverick XLT AWD
Sharp Maverick. Did putting the larger tires on it screw up the speedometer and odometer (speed reads slow and odometer reads short)? I'd bet you took an MPG hit by adding the larger tires, too. But, it does make the truck more capable off-road!
waxwins16
waxwins16
Brennon
Georgia
I have compared it to my speed on Waze and Google maps it seems to be the same. Slight 1 mpg hit as well.
waxwins16
waxwins16
Brennon
Georgia
Thank you!
mtneerdan1987
Daniel
Summersville, WV
Wanted to show off some of upgrades on my 2022 Maverick lariat. I used the ole ZEP trick to black out the taillights and used a tint to smoke out the top half of the headlights to not reduce visibility. I also decided to add the black lettering on the back to make the Maverick pop. The last and perhaps most important step to top it off is to add the 245/60 r18 Venom Power Terra Hunter X/T tires on it. I also decided to remove the side steps that were included to give it more ground clearance. The tires have been great and I have no rubbing or modifications outside of just adding the larger tires. Let me know y'all's thoughts.
Dude, can you explain how you did the black lettering on the tailgate (materials used, where to buy, technique, etc.)?
