Mud flaps recommendations?
hcforde
Hawley
Austin, TX
Honda Insight, E350, Toyota Sequoia
I thought the Ford mud flaps were way too expensive when I was doing the build. I am going to make my own with some stainless steel sheet I have. I may or may not spray them with some bed liner material, not sure yet.
29savoy
Robert
St Mary's ga
2022 Maverick xlt
I just installed a factory set of mudflaps on my XLT.The left rear had no where to mount the hardware,just open space by the muffler What did I miss?Anyone have a picture?Thank you.
mdl20813
Idaho
Cactus Gray Maverick XLT
Ford Maverick Mud flaps recommendations? 67ECAD0C-75AB-4AB2-B9D7-C736B466E7C9
Should just be the push pins in the wheel well and then you tap a 7mm hole into the bumper for the bracket
XLTLUXA51
Ezra
Hardwick Vermont
Ninja 650r, Suzuki SX4, Buell blast 500
I got caterpillar mud flaps on Amazon. I don’t have my maverick yet though so I can’t comment on their fit
Caterpillar Heavy Duty Splash Guards Pro Mud Flaps Fenders - Ultra Tough Dirt/Slush Protection with Night Reflectors - Easy Installation (2 Pcs for Front/Rear Tires) (CAGD-080_ALT)
Mabcim
Rochester, NY
dddinstructor
Hiram
Honolulu, Hawaii
XLT FWD, 2.0L Ecoboost Engine, 8-spd Automatic
The Ford OEM mud flaps have a good attachment system, using both push type rivets and mechanical screws. Added to that are clips and metal brackets for the rear flaps. The Ford OEM mud flaps work really well in protecting your vehicle and looks proportionate in size and appropriate styling for the Maverick.
Lyle
Lyle
Wichita
Dakota
I was looking at the Rokblokz site, didn’t see a way to place an order, even though there was a shopping cart shown at the top of the page.
testa422
Charlotte, NC
Subaru Legacy
Search by vehicle and there will be an “add to cart” option
Lyle
Lyle
Wichita
Dakota
I had to send them a message about the lack of an order button. They sent back their apology and said the issue had been fixed. Went in to their site and yes it was working and the mud flaps are now ordered.
scotwhoo
Scott
Pine Grove, CA
Ford Maverick 2022 XLT Hybrid
I got these off Amazon and mounted them this week. $24.99 for the pair.
I used 3 locations already on the fender. Top was plastic push pin replaced by a bolt, two washers and a nut. The too lower 7mm head screws took a little longer screw with washer.
These look great. I bought them, but can't figure out how to install on the back near the exhaust pipe. Any chance you can take a picture of what you did?
