MPG Calculater Adjustment. You can change setting for more accurate MPG Calculations.
agmonaco
Tony
Pittsburgh
2024 Ford Maverick Hybrid
A fellow Maverick owner gave me the gouge on how to do this. But I have a question for you software engineers. How much do you change the original setting in the settings of the truck? I was told to press the start button (Brake Off) on my Hybrid and the OK button on the Steering Wheel at the same time. An "ET" will appear to the Right of Power Gauge. Now you can scroll through many settings one being an MPG Adjustment setting. As you can see in the picture I lowered the factory set value from 1000 to 995 to see what happens. (Seems like the adjustment should be more for a 5% adjustment off of 1000 to lower 2 MPG, more like to 950 but I don't know.) Can any of you software engineers give the gouge on how much to move the value per 1 MPG change?
Ford Maverick MPG Calculater Adjustment. You can change setting for more accurate MPG Calculations. MPG
agmonaco
Tony
Pittsburgh
950 / 1000 is what it should be.
Some use 945 or 955 but 950 is a good place to start.
ok Thx.. just set it to 950 since I was showing 38 MPG when I actually was getting 35 MPG freeway driving
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
These shown below your thread will now give you more info.
Ford Maverick MPG Calculater Adjustment. You can change setting for more accurate MPG Calculations. 1751582542433-ev
Bradley
Bradley
Tennessee
2017 F150 King Ranch, Lincoln GT, 1969 Mercury Cougar, 2025 Maverick Lariat
heady
MI
'25 Lariat
Maybe you can turn the AFE correction up above 1000 too, and make the dashboard estimate even higher! Then when you post pics of your instrument cluster people will be even more impressed. Might get the first 60mpg+ Maverick 😁
