I did look a bit in the forum first ... ... but no luck, so ... Does FORSCAN address these options, at all, but specifically ... in the GLOBAL WINDOW settings like for the KEYLESS (Lariat) fob?
The power sliding window button for the rear is coded into the HVAC. Ill look into this some more.I did look a bit in the forum first ... ... but no luck, so ... Does FORSCAN address these options, at all, but specifically ... in the GLOBAL WINDOW settings like for the KEYLESS (Lariat) fob?
BTW ... where is / what is ... the 'screenshot' from?The power sliding window button for the rear is coded into the HVAC. Ill look into this some more.
Ok ... the journey begins
updated and found this too but idk.Check that link, doesn't seem to work ...
There may be some code for it for another model, but at least as far as the wiring diagram for the Maverick indicates the power sliding window operation circuit is pretty analog and has no module control.The power sliding window button for the rear is coded into the HVAC. Ill look into this some more.
No "Es' in my degree but I'll buy THAT as pretty definitive ... looks like it's back to just REMEMBERING to shut the darn thing !! Guessing (thinking) the same might apply to the MR.There may be some code for it for another model, but at least as far as the wiring diagram for the Maverick indicates the power sliding window operation circuit is pretty analog and has no module control.
I wonder if a separate remote control module could be used to power the roof separately. I hate that I forget to close the thing at night because its actually pretty quiet with It open. I wish it had dash light or something to remind you its open when you shut the truck off.No "Es' in my degree but I'll buy THAT as pretty definitive ... looks like it's back to just REMEMBERING to shut the darn thing !! Guessing (thinking) the same might apply to the MR.
Well sleuthed ... Sir
Or ... the DDHH (Dreaded Double Horn Honk)I wonder if a separate remote control module could be used to power the roof separately. I hate that I forget to close the thing at night because its actually pretty quiet with It open. I wish it had dash light or something to remind you its open when you shut the truck off.
Just curious, what are you trying to do/change? I dutifully reach up to operate my sunroof and down to operate my sliding rear window.I did look a bit in the forum first ... ... but no luck, so ... Does FORSCAN address these options, at all, but specifically ... in the GLOBAL WINDOW settings like for the KEYLESS (Lariat) fob?
dutifully ... I'll work on THAT.Just curious, what are you trying to do/change? I dutifully reach up to operate my sunroof and down to operate my sliding rear window.
