Maverick Lobo Autocross Testing & Handling Upgrades
DMS
Edmonton, Alberta, Canada
2025 Ford Maverick Lobo
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014342
Backstory:
I've been involved in Autocross and Time Attack events since 2018—competing, running clubs, and for the last three years, running my own series.
I had been struggling to find a vehicle that could haul gear, tow a small cargo trailer, and still be fun to drive.
Enter the damn-near-perfect vehicle for the job: The Lobo!
I purchased it two weeks ago and have already done some testing to figure out what modifications it needs to handle better—while still being a comfortable daily driver.
The good news? It's actually fairly well-sorted in stock form and only needs a few basic upgrades to make this little truck handle like a sports sedan.
AutoX Testing:
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014272
In stock form, I took it to one of my own events—StratoCross—which is an AutoX held on an oversized go-kart track called Stratotech Raceway.
With the truck having only 200 miles on it, I kept the acceleration tame. I just wanted to do a few runs to see how it behaves at the limit and where it needs improvement.
First impressions:
  • The stock tires are awful. Just light braking into the first corner caused them to lock up instantly, with ABS going crazy.
  • The stock seats have almost no bolstering. Braking and turning right had me slamming into the door panel; a sharp left and I was bashing my knee off the dash and leaning over the center console.
This is going to be an abusive relationship.
After a few events, I can confidently say: the truck, in stock form, is surprisingly well-sorted for what it is—except for the tires and seats. It turns decently, has some off-throttle rotation, and enough torque to pull out of corners. The traction/stability control is a bit too intrusive in Lobo mode, which is crucial for AutoX.
I did learn that if you press & hold the ESC OFF button for ~5 seconds you can further disable it!
The main issues are:
  • Dialing out the inherent understeer
  • Improving how it transitions
  • Better braking
Swapping to proper tires will solve most of these issues. A few minor suspension tweaks should make it easier to carry more speed through corners & transition faster.
The Goal:
I set a baseline time against the top driver in my area. On average, the Lobo was 7.5 seconds slower over a 50 second course than a stock but properly-prepared Civic Type R for AutoX.
My goal: make a few basic modifications to bring it into mid-pack territory in overall results—just enough to annoy your average Corvette or FRS/BRZ driver.
To do that, I need to cut about 4 seconds. Totally doable!
Mod List Plan:
  • Better Tires
  • Better Seat
  • Stiffer Rear Sway Bar
  • Lowering Springs
  • Performance Alignment
Better Tires:
This is the biggest factor—80% of the performance gains will come from better tires.
Since I’m sticking with the stock 19x7.5" rims for the rest of this season, my options are limited. To maintain stock diameter, the best tires I found were a few UHP-rated summer tires, but none are ideal AutoX tires.
I went with Firestone Indy 500s in 245/50/19. They're far from great, but good enough to help me close that 4-second gap—and they’re cheap.
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014378
Next season, I’ll upgrade to lightweight 20” wheels and proper 200TW tires, once sizes are back in stock. That alone should knock off another 1.5–2 seconds.
Seat:
The stock seats are unacceptable for any spirited driving. You flop around during transitions, and as grip increases, the problem gets worse. It's hard to drive with precision when you're all tensed up trying to stay up right.
I'm currently looking for a comfortable, bolt-in solution. A Focus ST seat swap might be the way to go.
Rear Sway Bar:
Most OEM setups are tuned to understeer for safety, and the Maverick is no exception. For AWD vehicles, it’s common to run the stiffest rear sway bar available to improve rotation.
I went with the Goodwin Racing rear bar
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014249
Springs:
One issue with the Maverick is its height-to-track-width ratio. Some AutoX events require a 1:1 ratio. The truck sits at ~65" tall with a ~63.5" track width—about 1.5" off the requirement.
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014227
As a daily driver, I still want a comfortable ride. Lowering springs are a simple fix that also improve handling.
I bought a Goodwin Racing spring + sway bar package. The spring rates are only slightly stiffer than stock, so they still work well with the OEM shocks.
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014224
Note: Even with these springs, I’m still ~½” too tall for the 1:1 rule. However, most organizations should still allow it. If needed, H&R Super Sports might get you within spec.
(In my region, they go by overall width, not track width—so it's allowed in stock form.)
Alignment:
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014365
Lowering gave me about:
  • -1.0° front camber
  • -1.3° rear camber
But the front still needs more camber to reduce understeer & the toe needs to be zeroed out to help it turn in better.
I installed Eibach camber bolts to get the front camber close to -2.5°—the usual max for a daily without excessive tire wear.
I'll be setting:
  • Front toe: 0° (from factory toe-in)
  • Rear toe: 0° (from factory toe-in)
  • Front Camber -2.5°
  • Rear Camber -1.3°
Upcoming Testing:
I have a few more AutoX events lined up. We’ll see how close I can get to knocking off that 4-second gap with these basic mods!
*Update- The Changes listed knocked off more than 4 seconds!
Autocross Classing Issue:
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 1000014324
If your local club uses SCCA classing, the Maverick technically doesn't meet the height-to-track-width requirement and won't be classed.
However, I entered it into G Street Touring without issue.
TL;DR: How to Make Your Maverick Handle Like a Sports Sedan
  • Replace stock tires with UHP summer tires or better
  • Install a stiffer rear sway bar
  • Lower with sport springs
  • Install front camber bolts and set camber to -2.5°
  • Set front & rear toe to 0°
  • Replace the front seat!
Updates
How-To Write Ups
How to install Camber Bolts
How To Set Toe to 0°
How to turn off AdvancedTrac ESC
Chops
Lobo
What a great post! Looking forward to following your progress. The Firestone Indy 500s in 245/50/19 is my next tire. Glad to see it fits…
alex lobos
Alejandro
Chicago Illinois
2025 maverick LOBO
Man I love this. It totally gives me a good baseline on when I start doing suspension mods. I really want to take my lobo to the track next year and been pricing soft compound tires. I wanted the Goodwin setup and now you’ve just reinforced my thoughts on it. Any thoughts on strut brace?
this is a really great post, thank you for all the details!
YeenBean
Alberta Canada
25 Maverick XLT 2.0l EB
Backstory:
AutoX Testing:
First impressions:
After a few events, I can confidently say: the truck, in stock form, is surprisingly well-sorted for what it is—except for the tires and seats. It turns decently, has some off-throttle rotation, and enough torque to pull out of corners. The traction/stability control isn’t too intrusive in Lobo mode, which is crucial for AutoX. Sport mode, however, was a bit too intrusive when pushed.
  • Better braking
The Goal:
Mod List Plan:
  • Better Tires
  • Better Seat
  • Lowering Springs
Better Tires:
Seat:
Rear Sway Bar:
Springs:
Alignment:
  • -1.3° rear camber
But the front still needs more camber to reduce understeer.
I’ll be setting:
  • Rear toe & camber: can't be adjusted without aftermarket links
Going to Zero toe improves turn-in response.
Upcoming Testing:
  • Install front camber bolts and set camber to -2.0° to -2.5°
  • Set front toe to 0°
Stratotech huh? I'm from the area. Grew up around here and loving your build. Might consider doing an autox with my mav sometime too. Shame it's a bit too tall out of the box. I've got a bone stock XLT Ecoboost. Wonder if id ride the same height as yours with springs
DMS
DMS
Would not bother with a strut brace. They do little to nothing in terms of actual measurable performance. Spend the money on better tires, or a nice dinner.
Chops
Lobo
Hey, I appreciate my strut brace! Why are they so common in SCCA racing - just for looks? Nothing wrong with that I suppose:)
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades IMG_9276
shadow_munk
Lobo
What setting did you go with on the sway bar. I'm eventually going to put mine on (when its not so hot) but im mostly daily driving compared to you
DMS
DMS
The stiffest setting. I probably would go with the middle setting if your only daily driving it to reduce wear on the endlinks.
DMS
DMS
There just ain't no way you're generating high enough cornering forces in a mostly stock Maverick to have camber loss issues due to the strut towers flexing. All those soft rubber bushing in the stock suspension will be an issue before the rigidity of the strut tower is.
Chops
Lobo
Thanks for your thoughts. Would all the soft rubber bushings impact the effectiveness of anti-sway bars?
stangg17
Chicago
Great post!
Regarding the seat, have you considered a schroth harness? They make ford compatible quick disconnect harnesses. I used to autocross a gti and had the same seat issue. After researching golf r seats and getting sticker shock, I went with a schroth harness and it made all the difference. The quick disconnect feature is also very appealing since I daily drove the gti. Additionally, I've been taking a look at used RS/ST seats and they are also expensive or best to hell.
NIKwithoutaC
Nik
Indiana
1986 Mustang, 2026 Maverick Lobo Sport
Awesome thread. Very curious to see how the changes affect handling and lap times.
DMS
DMS
Great post!
Yes, definitely considering the Schroth Quick Fit as part of the solution. Had one in a previous car. The price of used ST seats are insane for what they are.
Picture attached for those wondering what the hell a Schroth harness is.
Ford Maverick Maverick Lobo Autocross Testing & Handling Upgrades 967_quickfit_installation_graphic_
DMS
DMS
Yes. Soft swaybar bushings will soften the rate of the swaybar a bit.
