Maverick factory wheels specs
oljackfrost
Minnesota
I plan on using the stock Maverick XLT wheels for my winter tires. Because I’m an older guy, I like wheels with a little sparkle, black doesn’t do it for me. Here is what I have been able to put together for Bronco Sport 17” wheel specifications, if anyone has any info on whether the Maverick will be different, let us all know.
Wheel diameter 17”
Wheel width 7”
Bolt pattern 5 x 108 mm
Offset 37.5 mm
2cafn8d
Monica
Huntington Beach CA
2022 Maverick XLT
I would also like to follow along. It would be awesome to have a set of wheels waiting for delivery :)
Chasmccall
Charles
Phila., Pa
2022 Maverick xlt
Wheel diameter 17”
Wheel width 7”
Offset 37.5 mm
From what I've read on here that is all correct for the Maverick except the offset, which I believe is 38 mm
zackmd1
Zack
Maryland
1970 Mustang 429BB / 2019 Tesla Model 3
Plan on replacing my XL wheels on day one…. The biggest limiting factor I have found is the bolt pattern. It’s an unusual pattern for anything other then cars so finding wheels with an adequate load rating has been a challenge and will likely be that way moving forward unless the aftermarket better supports the Maverick.
Method race wheels have a few options. I’m currently thinking of the Method MR502 16x7 with a 30mm offset wrapped in either a 245/70r16 or 255/70r16. From what I have seen on the bronco sport forum, the 245 is likely the safe option at 29.6” diameter for no rubbing while the 255 at 30.1” diameter will likely be just on the edge of no rub at full lock. This of course is assuming the Maverick wheel well and suspension is identical to the Sport…
2cafn8d
Monica
Huntington Beach CA
2022 Maverick XLT
Sparco has some fun wheels. I'm seriously looking. I would love a set of Terras, but they only come in 5x100.
oljackfrost
oljackfrost
Minnesota
Make sure those 16” wheels clear the rotors, stock is 17” so you might have clearance issues.
zackmd1
Zack
Maryland
All my info currently is from a Bronco Sport so still all assumptions…. That being said, the sport does support 16” wheels. Some on the forum site have gone with 16” Steelies.
HarrisonFordMaverick
Arizona
Subaru Outback
I'd wait and see on 16" wheels. Especially if you are going with the 4K tow package, I know it doesn't state it but the brakes may be larger on the Maverick since it is designed to haul more than the Bronco Sport and has a higher payload.
Tq28tz
St Louis
NSX, 911, 240z
oljackfrost
oljackfrost
Minnesota
If you search Tire Rack or Discount Tire for Bronco Sport wheels, you will find hundreds of wheel designs.
Flyfishing
Catskill Mountains
2022 Ford Maverick XL AWD
do you know the information for the xl stock rims and tires? I’d like to post mine for sale a week before she comes in and have new shoes ready first day. Thank You
