SaintCowboy
Tyler
us
This guide provides the definitive step-by-step instructions for installing a dual battery and inverter system in your 2022 Ford Maverick XL (2.0L AWD). This post focuses exclusively on the base setup, covering the battery, inverter, and wiring. Separate posts will detail appliances and accessories.
Accessory Guide: https://www.mavericktruckclub.com/f...-dual-battery-inverter-accessory-guide.60801/
Introduction
Installing an auxiliary battery and inverter system in your Ford Maverick transforms it into a utility powerhouse, perfect for camping, work, or off-grid adventures. Follow this guide to replicate my proven setup, using exact components and wiring methods for reliable, efficient performance.
Components and Costs
Here’s the exact list of components I used for this setup, with links for purchase. Prices reflect what I paid and typical sale prices.
Components
  1. Battery:
  2. DC-to-DC Charger:
  3. Inverter:
  4. Circuit Breakers:
  5. Wiring:
  6. Wire Terminals:
Total Cost
  • Total cost (without tools): $1,505
  • With the inverter on sale for $150, the total cost drops to $1,376.
Tools You'll Need (Not Included in Cost)
  1. Hydraulic Wire Crimper
  2. Multimeter (Optional but recommended)
  3. Heat Gun
  4. Wire Stripper
  5. Socket Wrench Set
  6. Drill (If mounting components)
  7. Zip Ties
Step-by-Step Installation
Step 1: Component Placement
I placed all the components under the rear seat for a compact, clean setup:
  • Battery: Under the passenger-side rear seat.
  • Inverter: Under the driver-side rear seat.
  • DC-to-DC Charger: In the middle under the rear seat between the battery and inverter.
  • Circuit Breakers: Mounted behind the rear seat backrest for easy access.
Step 2: Mount the DC-to-DC Charger
  1. Mount the Renogy 50A DC-to-DC Charger in the middle under the rear seat.
  2. Leave clearance for wiring and airflow.
Step 3: Wire the System
Your wiring ensures all positive connections pass through a circuit breaker before continuing to the next component, and all negative connections connect in sequence, ultimately grounding to the frame via the auxiliary battery.
Starter Battery to DC-to-DC Charger
  1. Positive Connection:
    • Connect 1/0 AWG wire from the starter battery positive terminal to the input terminal of the first circuit breaker.
    • From the output terminal of this circuit breaker, connect 1/0 AWG wire to the input terminal of the DC-to-DC charger.
  2. Negative Connection:
    • The starter battery's negative terminal remains grounded to the truck frame (already factory-grounded).
DC-to-DC Charger to Auxiliary Battery
    • Connect 1/0 AWG wire from the output terminal of the DC-to-DC charger to the input terminal of the second circuit breaker.
    • From the output terminal of this circuit breaker, connect 1/0 AWG wire to the auxiliary battery's positive terminal.
    • Connect the negative terminal of the DC-to-DC charger to the auxiliary battery’s negative terminal.
this is where you put the dc to dc alternator cable thing… not sure what to call it at this point but it is required to let the dc to dc charger know when the car is on and alternator is running. You can look in the dc to dc charger to see which fuse type they recommend as I forgot to document this piece. But with that information you google ford maverick internal fuse box diagram and pick the relevant fuse. If I remember correctly you can use pretty much any of them just make sure it isn’t one that is constantly on like even when the truck is off. And don’t use the driving sensor ones pick something like heated seats or low importance. I then went on line and got a fuse tap from Amazon they are $5. Highly recommend so it has an OEM fitment and doesn’t come loose.
Auxiliary Battery to Inverter
    • Connect 1/0 AWG wire from the auxiliary battery’s positive terminal to the input terminal of the third circuit breaker.
    • From the output terminal of this circuit breaker, connect 1/0 AWG wire to the positive input terminal of the inverter.
    • Connect the negative terminal of the inverter to the auxiliary battery’s negative terminal.
Final Grounding
  1. Connect the auxiliary battery’s negative terminal to the truck framefor grounding.
    • Sand down the paint at the grounding point to ensure proper contact with the metal.
  2. The truck frame serves as the common ground for the entire system.
Summary of Wiring Flow
  • Positive Path:
    • Starter Battery → Circuit Breaker → DC-to-DC Charger → Circuit Breaker → Auxiliary Battery → Circuit Breaker → Inverter.
  • Negative Path:
    • All negative terminals connect in sequence: DC-to-DC Charger → Auxiliary Battery → Inverter → Frame Ground.
Step 4: Test the System
  1. Verify all connections with a multimeter to ensure proper voltage and continuity.
  2. Flip all circuit breakers to the ON position.
  3. Test the inverter by plugging in a small device, such as a phone charger or appliance.
Step 5: Secure and Clean Up
  1. Organize wires using zip ties.
  2. Double-check that all components are secure and protected.
Maintenance Tips
  • Check Connections: Inspect for corrosion or looseness every 3-6 months.
  • Monitor Battery Voltage: Keep the battery within the recommended range to extend its lifespan.
Proven Reliability and Durability
I’ve been using this setup in my Ford Maverick for the past six months, and it has performed flawlessly. This system has been tested in extreme conditions, including the 120°F heat of Phoenix, AZ, and the -2°F cold of Flagstaff, AZ, with no issues whatsoever.
Additionally, my truck was involved in a hit-and-run accident, and despite significant vehicle damage, my auxiliary power system remained intact. The service center inspected the truck and confirmed that my installations caused no issues with repairs. I also inquired about warranty concerns, and they assured me that the auxiliary system is completely separate from the truck’s systems, so warranty coverage should never be affected.
This setup is truly built like a tank and has supported multiple appliances I’ve installed, all of which function perfectly. I’ll detail these appliances and their installations in future posts, which I’ll link here once published.
Disclaimer
The information provided in this guide is based on my personal experience and the specific setup I have tested in my Ford Maverick. While I have thoroughly tested this system and ensured its reliability in my truck, these instructions are provided as-is and may not work for every vehicle or situation.
By following this guide, you acknowledge that:
  • I am not a certified electrician or mechanic, and this is not professional advice.
  • You are solely responsible for any modifications you make to your vehicle, including any damages, malfunctions, or warranty issues that may arise.
  • Any actions taken based on this guide are done at your own risk.
I strongly recommend consulting with a professional if you are unfamiliar with automotive electrical systems. Always prioritize safety and double-check all connections. I am not liable for any issues resulting from your use of this guide.
Dad
Just an amazing and informative post! Thank you for taking the time and effort to script, organize, and photograph your modification. If only other installation manuals had this kind of attention to detail. Consider yourself the poster guy for why this club is such a fantastic source of information, assistance, and good people.
SaintCowboy
Tyler
us
Thank you I really appreciate it. I only hope it helps someone else looking to do the same thing in the future!
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
FYI, the battery you linked is on sale for 519.99!
nice write up. most of the inverter setups I've seen are for hybrids, which have an advantage in that you can leave them running and they simply start and stop the gas engine as needed.
what's your method of using this camping etc? how do you know when it's time to fire up the engine and recharge everything?
SaintCowboy
Tyler
us
Now’s the time to get this done I guess took me and a friend one night and a case of beers to do!
SaintCowboy
Tyler
us
My fridge/freezer lasts 15 days on normal fridge mode without starting it up. It charges my makita powertools all day I’m a superintendent so I use it a lot and run power tools it’s never died
SaintCowboy
Tyler
us
Really nice write up. 3.6kwh (300ah) is a lot of juice for the weekend!
Yeah some people don’t understand how long this will last I haven’t had it die once and I have a fridge running almost 24/7 And leave it on for weeks at times without starting it
count me as (previously) one of them. I really had no idea how much more capacity you have here, because of the size of the battery. but Google tells me that an average 760cca battery has around 100 aH capacity, so your battery is triple that capacity.
still, I assume we're talking about a pretty small fridge/freeze and not on 100 degree days?
Carlitos_92
FWIW, Renogy sells a Bluetooth module for $25 that will give you monitoring capability on a smartphone.
SaintCowboy
Tyler
us
Nope I ran it all summer in AZ worked great in 120degrees. But during the summer in that kind of heat I just took the safety precaution of disconnecting the circuit breaker between the dc-dc charger and the the lithium battery. No reason other than lithium’s hate being charged in that weather simply to just preserve its life!
But I would like to mention this battery has double the capacity that most van lifers put in their rigs!
SaintCowboy
Tyler
us
Funny you say that mine just came in I will be including it in the next tutorial for installing all the extras and leave the thread linked in the original post. My goal is to make the holy Bible of auxiliary, power and utilities for the Ford Maverick!
Dad
Now THAT Is what I call custom work. Super cool.
