Mav outside in single digit temp's. Got check engine light and car wont start
kkgg
Minneapolis
Lariat AWD.
Brand New, parked outside in single digit temp's for 2 days. Got check engine light and car wont start.
Looks like battery is giving the ignition(click sounds) but car won't start.
Any ideas please. I see these messages in the ford pass app
Ford Maverick Mav outside in single digit temp's. Got check engine light and car wont start Screenshot_20221218-202643
Ford Maverick Mav outside in single digit temp's. Got check engine light and car wont start Screenshot_20221218-202638
Ford Maverick Mav outside in single digit temp's. Got check engine light and car wont start Screenshot_20221218-202630
Ford Maverick Mav outside in single digit temp's. Got check engine light and car wont start PXL_20221217_222332526
jsus
2022 Ford Escape Hybrid AWD
Sounds like you'll want to contact Ford Roadside Assistance in the morning to have it towed to your dealer to have it looked at under warranty. Unless, of course, someone has any suggestions on things you can try at home. Sounds like an issue with the fuel pump, though, which is something the dealer should generally handle.
Your vehicle purchase includes 5 years/60,000 mi of roadside assistance.
It sucks but anything mass produced can have teething issues. Let us know how the repairs progress.
https://www.ford.com/support/category/service-maintenance/roadside-assistance/
kkgg
Minneapolis
yeah it sucks, thank for the advice
Waterick
Laurens county SC
Maybe the battery could not take the cold. Possibly not enought juice to run starter or fuel pump? Try charging it. Then get ( if it works) get a new battery through Ford.
S. fisher
Interior Alaska
01 2500 HD, 15 Santa Fe, 94 XJ
Sounds like it needs to be winterized. Did you order it with the block heater, then have the dealership install trans pan heater, oil pan heater, and battery tender? You live in a cold climate, it’s hard on any vehicle.
Dale Ducheneaux
Dale
Canton, South Dakota 57013
Ordered 2023 Maverick XLT 9/16/22
remove the battery and bring it in the house to thaw out. then put a charger on it let charge and then install and try to start.
kkgg
Minneapolis
Thanks guys.
I tried again now, is started after few attempts by itself.
So I went for a drive (20 miles) and came back(hoping that would charge the battery).
The check engine light is still on. Can I do anything for it to go away ?
fossil
ernie
ohio
Same one I have (different brand name) and it's started my 6.2L V8 a couple times with no problem
Potato bread
Jonathan
North Pole
2022 ford Maverick
Lariat AWD.
Lariat AWD.
I am fully weatherized in North Pole AK. I keep mine plugged in, and have zero issues starting. Block heater, trickle charger, oil pan heater, and transmission heater. Good luck.
Ford Maverick Mav outside in single digit temp's. Got check engine light and car wont start Screenshot_20221218-185104_One UI Home
S. fisher
Interior Alaska
And when it’s-44 next Friday yours will still start. Cheers!
KSC Grey Ghost
Tn
Jeep
You got me a little concerned. I have a hybrid and that big Polar Vortex is coming down Thursday Friday and Saturday 0 to 5 degrees??🤔❄🌨🥶. Well I guess I will find out 🤥
