Masterlist of functions possible with FORScan??
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
They were referring to the OBD Auto-start eliminator.
But the fact is there's no known way in FORScan to disable auto-start or change default drive mode.
You talking about The auto stop start?
KenJ45
KenJ45
2022 Ford Maverick XLT 2.0L Ecoboost
The auto start/stop. That annoying feature where when you stop at a stoplight it shuts off your engine, then starts it again when you release the brake pedal, wearing down your starter at a much higher rate than normal...
ALTOXLT
2022 Maverick XLT gas
I have a question… I enabled the SSR and it works as it should. But when you exceed the selected MPH over the sign flashes continuously, that’s annoying. Anyway to stop that from happening?
It becomes a setting in the vehicle settings
Old_Norm
Norm
Columbus Ohio
2023 Mustang Mach E 2023 Maverick Lariat
I imagine the starter in the Mav Hybrid was designed for the higher useage. I remember riding in Mercedes taxis in Cario, Egypt, and elsewhere overseas, in the early 80s and they had stop/start systems even back then. I never heard of a problem with the startes then or now. BTW, they were disel motors. You definitely knew when they shut off and started again.
KenJ45
KenJ45
Doesn't matter, if it's designed for higher use, then that should just mean it'll last even longer than a normal starter if you don't use auto start stop. Not to mention, I live in South Florida, where air conditioning is not a luxury, but a necessity. When the engine isn't running, the AC doesn't blow as cold, so no matter what, designed for it or not, I don't want to ever use it period.
Old_Norm
Norm
Columbus Ohio
I wasn't comenting on wheather to use it or not. I was only addressing your speculation about start stop, "...wearing down your starter at a much higher rate than normal."
dearbulls
Dan
GA
Bump. Would love to see this
There is no "starter" in the hybrid - subject you commented on was the feature most newer cars have just like the EB engine does.
You have hybrid - KenJ has EB.
JBuss
Jonathan
Virginia
2024 Ford Maverick XLT : Terrain/FX4/LUX/TOW
