Nickd
Lariat
Nick
Summerville, SC
2022 Maverick Lariat
Trim
Lariat
Lariat lux with around 500 miles. Fwd lowered on H&R fwd escape springs with 20x8.5 rotiform wheels. 245-45-20 tires. Rides good no rubbing and a little poke out front. Need to get the front down another 1/2 inch or more.
catinthebathtub
XL
haas
houston
66 GT 350, 36 coupe, 34 pickup and porsches.....
Trim
XL
Vehicle Showcase
have you aligned yours after the spring install?
mine has lots of toe in (rear) that cant be adjusted out. and it must have been that way from day one, lowering springs shouldn't affect toe on the FWD turbo rear suspension design.
Nickd
Lariat
Nick
Summerville, SC
Trim
Lariat
They got it pretty close, seems to drive good so far
catinthebathtub
XL
haas
houston
Trim
XL
Vehicle Showcase
thanks for posting your results. mine didn’t come in as good.
fyi, i build and race old porsche crap and have alignment and corner weight stuff built especially to have the fastest old 911’s in the world - so the specs are meaningful. thanks again for sharing.
Nickd
Lariat
Nick
Summerville, SC
Trim
Lariat
Agreed they do matter!
1stE
XL
usa
muscle car
Trim
XL
Vehicle Showcase
Havick
XLT
Chad
Windsor, ON
2019 F-150 & 1988 Mustang GT
Trim
XLT
Looks great. These trucks look so good lowered.
Stroked
XLT
Donald
Central Maryland
2022 Xlt Maverick, 2019 F350, 49 Ford Tudor
Trim
XLT
I recently did mine also, what did you do for rear spring retention? If you have the suspension at full travel, be it on a lift, or whatever, the spring falls out
I have a limiting cable on now, i have a catalog to dig through from bilstein, was hoping to hear someone has found some shorter shocks
Connect
JD
Tx
2013 Honda Accord, 2014 Nissan Rogue
Trim
looks really good!
Ratbones2002
Lariat
So Cal
2022 Maverick Lariat Hybrid
Trim
Lariat
You might want to research some rear shocks from a 1966-1977 Ford Bronco. A fellow Maverick owner used them on the rear because they are shorter.
Hennessy
Lariat
Johnny
Colorado
Maverick carbonized grey Lariat
Trim
Lariat
What is the clearance like on it? I unfortunately have snow so I need some clearance but love the look and is making it hard to not lower it after seeing exactly what it would look like!
Nickd
Lariat
Nick
Summerville, SC
Trim
Lariat
I will have to take a look, had mine jacked up to swap wheels and the springs were loose but did not fall out. I had a shop instal mine
Nickd
Lariat
Nick
Summerville, SC
Trim
Lariat
Clearance is not bad at all and ride is surprisingly smooth for being lowered. I have run my full size trucks lowered for years in the western ny winters without issue
Stoopid313
Lariat
Jesse
Indiana
2013 F-150 Lariat 5.0
Trim
Lariat
Do you know what the offset/back spacing is on these wheels?
