Nickd
Nick
Summerville, SC
2022 Maverick Lariat
Lariat lux with around 500 miles. Fwd lowered on H&R fwd escape springs with 20x8.5 rotiform wheels. 245-45-20 tires. Rides good no rubbing and a little poke out front. Need to get the front down another 1/2 inch or more.
Ford Maverick Lowered fwd Maverick on H&R Escape springs, 20" Rotiform wheels, 245-45-20 tires 220CAEC2-999F-4189-A0FE-DF9D1C4A9D56
Ford Maverick Lowered fwd Maverick on H&R Escape springs, 20" Rotiform wheels, 245-45-20 tires 903FDD28-B700-4557-91C3-44628392EB82
Ford Maverick Lowered fwd Maverick on H&R Escape springs, 20" Rotiform wheels, 245-45-20 tires 747E0EC2-EBE9-4F11-AD96-5C163ECA880F
catinthebathtub
haas
houston
66 GT 350, 60 VW, 34 pickup and porsches....
have you aligned yours after the spring install?
mine has lots of toe in (rear) that cant be adjusted out. and it must have been that way from day one, lowering springs shouldn't affect toe on the FWD turbo rear suspension design.
Nickd
Nickd
Nick
Summerville, SC
They got it pretty close, seems to drive good so far
Ford Maverick Lowered fwd Maverick on H&R Escape springs, 20" Rotiform wheels, 245-45-20 tires A57B11EB-19AA-4A07-9B0A-F966118447EC
catinthebathtub
haas
houston
thanks for posting your results. mine didn’t come in as good.
fyi, i build and race old porsche crap and have alignment and corner weight stuff built especially to have the fastest old 911’s in the world - so the specs are meaningful. thanks again for sharing.
Nickd
Nickd
Nick
Summerville, SC
Agreed they do matter!
Havick
Chad
Windsor, ON
2022 FX4 Maverick & 1988 Mustang GT
Looks great. These trucks look so good lowered.
Stroked
Donald
Central Maryland
2022 Xlt Maverick, 2019 F350, 49 Ford Tudor
I recently did mine also, what did you do for rear spring retention? If you have the suspension at full travel, be it on a lift, or whatever, the spring falls out
I have a limiting cable on now, i have a catalog to dig through from bilstein, was hoping to hear someone has found some shorter shocks
Connect
JD
Tx
2013 Honda Accord, 2023 Maverick XLT Hybrid
looks really good!
Ratbones2002
So Cal
2022 Maverick Lariat Hybrid
You might want to research some rear shocks from a 1966-1977 Ford Bronco. A fellow Maverick owner used them on the rear because they are shorter.
Hennessy
Johnny
Colorado
Maverick carbonized grey Lariat
What is the clearance like on it? I unfortunately have snow so I need some clearance but love the look and is making it hard to not lower it after seeing exactly what it would look like!
Nickd
Nickd
Nick
Summerville, SC
I will have to take a look, had mine jacked up to swap wheels and the springs were loose but did not fall out. I had a shop instal mine
Nickd
Nickd
Nick
Summerville, SC
Clearance is not bad at all and ride is surprisingly smooth for being lowered. I have run my full size trucks lowered for years in the western ny winters without issue
Stoopid313
Jesse
Indiana
2022 Maverick Lariat awd eco
Do you know what the offset/back spacing is on these wheels?
