Light scratches from garage door scuffing rear bumper
Wmaverick
Wilbur
2023 Ford Maverick Tremor
Does anyone knows the best way to refinish a rear bumper with light scratches?
SafetyGuy
Andy
Manitoba
Good day, @Wmaverick
Can you add a photo of the scratches on your bumper to help those here who might be knowledgeable on bumper repairs?
They might be better able to assist with this important bit of information.
Have a good one, and sorry about your bumper scratches as that has got to suck.
Andy
Wmaverick
Wilbur
Sorry, should have added picture. Thanks
Ford Maverick Light scratches from garage door scuffing rear bumper IMG_20260105_114154
I'm going to guess. It is from this garage door hinge, hitting the bumper because truck was not pulled in Far Enough?
Just a guess.
I've gotten close myself. 😮
Ford Maverick Light scratches from garage door scuffing rear bumper 20260105_095033
Ford Maverick Light scratches from garage door scuffing rear bumper 20260106_124532
Cancunbadlands
Cancun
Cancun
VRP by Chemical Guy's
710-oil-614
Cal
2025 Hybrid AWD Lariat
I'd make sport but my front bumper got the business end of my garage door manual handle in case you ever have to open it on your own...
notfast
Los Angeles CA
That portion of the bumper is unpainted plastic, so there isn't a whole lot that can be done. Polishing it won't do anything and sanding it will just evenly scuff the rest of the bumper.
You can try a product like CeraKote trim coat to see how it looks with filling in the scratches, but they'll reappear when the product wears off.
MaverickDragon
Grand Canyon, AZ
Prevention is worth a pound of cure.
A tennis ball on a string hanging from the ceiling to let you know you are in a scrape proof parked position when it touches your windshield will help prevent further scratches.
Back to Black may help a bit to hide them.
Wmaverick
Wilbur
Thank you. I think I will try CeraKote trim. As long as it hide some of it Iwould feel better. I also have Mabette black wheel well trims that need some attention too.
JMJB
Fresno California
'22 VB XLT Hybrid with Sunroof
Well.....you know ....it is a bumper ....this is only the beginning ..... 🤣
710-oil-614
Cal
As someone who has a lot of experience with Cerakote and Ford MIC plastic - please don’t do that!!
I fear you’re going to trap the scratches beneath the ceramic bonding and make it even harder to get off
Wmaverick
Wilbur
Wmaverick
Wilbur
Thanks for the info. Do you have any suggestions? I know it's minor, but with all the Maverick owners that enjoy their truck I thought someone has experience this and perhaps have come up with a solution.
Do you think a body shop would be able to buff it out?
notfast
Los Angeles CA
You absolutely will, but that's sort of the point. Fill in the scratches with Cerakote and hope that it makes the appearance better. Sort of like how waxing fills in swirl marks and makes them disappear until the wax eventually burns or washes off.
I'm sure you're aware, but Cerakote isn't permanent. It eventually wears away in a sorta blotchy look. Speaking of which, I need to redo the Cerakote on the Frontier's bumper plastic, which is notorious for looking sun bleached, like the unpainted plastics on Chevrolet Avalanches.
It's unpainted, molded-in-color plastic; there is nothing to "buff out", unlike say, having hazy clearcoat. A few seconds with a rotary polisher and some cutting compound will make clearcoat glossy again. What's actually happening is you're sanding away a microscopic amount of the clearcoat that is hazy or oxidized.
But again, MIC plastic has no clearcoat or paint to buff. At best they may be able to blend the scuff by making the rest of the bumper look equally scuffed in texture.
A test I suppose you can try is just to spray the scuff with water. If it looks better, then Cerakote trim shine will probably help, but you have to do the entire bumper. Cerakote is closer to applying a very thin layer of high-gloss epoxy across the surface rather than a typical gel or spray trim shine.
