Removing light scuff marks from black rear bumper?
fossil
ernie
ohio
the more you mechanically work this scuff the worse it will look.
follow what @Maverickman74 suggested and try a hair dryer. mask off the scuff close and out a couple inches and then keep the dryer moving back and forth until the light colored scuff stuff melts slightly. not enough heat? step to a heat gun set on low. slow and careful is the key here.
heat will melt the roughened area and blend it in to minimize (not eliminate so don't try) the damaged appearance. too much heat will make the area shiny and imo look just as bad as the scuff.
me, I'd break out my Dremel multi function butane heat gun and have at it. we're old acquaintances.
Ford Maverick Removing light scuff marks from black rear bumper? heatgun
Dad
Dad
Always something to learn on this forum. Started out as removing scuff marks from the trim and suddenly my eyebrows perched up when I saw your Dremel multi-function butane heat gun.!
fossil
ernie
ohio
LOL, bought it for the wife's jewelry making hobby and ended up using it more myself for soldering and heat shrink.
caution, it won't handle rough treatment, don't toss it into the tool box.
  • Like
Reactions: Dad
Wilbur
Scottsdale, AZ
1967 Ford F100
Rather than beginning with a mechanical fix like a heat gun, you might start with cleaning up and chemically annealing the surface of the hard black plastic.
A cleaner such as Meguiar's Ultimate Black or Mother's Back to Black will clean any dust and other contaminants out the scuff marks and give you better visibility as to the actual mechanical repair that is necessary.
It may be that after a cleaning with Back to Black or whatever, you can see that the plastic needs re-work in specific areas and not others as a second step.
Fix4Dirt
Los Angeles, CA
2024 Ranger XLT 2.3 FX4 1998 Explorer XLT SOHC 4x4
detailer here. personally i find stuff like back 2 black unnecessary, since doing something like an IPA wipe or APC wipe down will show you what youre looking at. the issue with these is that it makes little gouges into the plastic and looks like plastic whisp so to speak. thats what makes somethin like a hair dryer a very very hard repair to get right since yeah if its one gouge maybe itll expand enough to fill that but with so many of them the closest i have gotten to a fix is snipping the tops of the whisps and then expanding
however, yours dont seem as deep as some I have worked with. in my experience (your mileage may vary) some heat helps bring back the OE color and then something liek back 2 black hides it fully and entirely the tiny tiny whisps may still be visible, but only to the trained and close eye. most likely no one will ever notice.
a few words of caution
if heated too much then the texture changes since it looks a tiny bit textured.
i see on the right side of the bottom scratch already no texture there, so texture wont really come back, dont expect there to be texture in that particular spot.
this is just my opinion based on my experience, others may be different.
Fix4Dirt
Los Angeles, CA
sound advice overall. one thing tho being that b2b or ub doesnt just clean, it also tries to darken plastics with oils etc, that can hide the under finish. similiar to polishes w/ silicones or whatever its called that makes certain ones not body shop safe, since oils int he formula can hide defects underneath. as such id suggest APC or IPA wipe to remove oils, preferably IPA
garyp
Washington
22 ford maverick
Amazing, originally a bumper was there to be tougher and take hits without damage and protect surrounding areas
MaverickNoticer
Dan
Smyrna, DE
Maverick '24 XLT
Does anyone know what I can use to get light scuff marks out of the black rear bumper? I came out of the store over the weekend only to find a shopping against my back bumper.Luckly I didn't have more damage done.It just show how stupid and lazy some people are not to put the shopping cart away!!
I'm wondering the same for scuffs all over the plastic on this truck. Love the Mav, but it scuffs if you breathe hard near it.
