Leveling kit options???
Jmav216
Justin
Cleveland
2022 maverick xl
I'm curious I know there's a 1-in lift kit for the front to make it even with the back I don't want to lift it I don't want to lower the whole vehicle I just want the stance to be more even but I'd rather have the rear end lowered to match the front end just to give it a little better stance is anybody done this or no if this is doable also how high is the rear end compared to the front?
JP4AZ
Phoenix
I hope you found an answer to this long ago. Yes, There is a 1 inch level kit from Rough Country (was on sale for $75.) That is basically just spacers on top of your strut towers. I purchased the metal spacers. They also come in a composite too. I do not have a Maverick yet, but it will get the leveling kit installed. Several video's on You Tube on how to install. Best of Luck
As to lowering the rear end, I would not mess with that, but if you do, Please post on this forum what was involved with that procedure!
Ford Maverick Leveling kit options??? 20230127_131558
Lhaddix27
Leanna
Wv
23 ford maverick
Do you know if these u have to decompress the strut ?
Lhaddix27
Leanna
Wv
23 ford maverick
Are these the ones you decompress the strut for ? I’m wondering if they make just bolt on or if u have to decompress the strut to install
Scooter66
Scott
Saint Augustine
2023 Bronco BaseSquatch; 2024 Maverick (murdered out)
They are the ones that don’t do anything at all
Lhaddix27
Leanna
Wv
23 ford maverick
What would
you recommend for making it set up higher. I’m wanting. To add height and. I’m wanting to put 245 70 17s on it
Scooter66
Scott
Saint Augustine
What would
I have yet to see a lift that doesn't mis-align the wheel in the wheel well. It's like the wheel gets shoved to one side of the wheel well. So I wouldn't go more than 1" (what the Tremor package does).
wax87
Stuart
Dallas South
2004 Avalon
Add 500lbs to the back? :eek:P
JP4AZ
Phoenix
no, All you do is put them on top of the strut/spring assembly. Very easy install. several youtube video's on the subject. You will need an alignment after install. I have not installed them yet, and probably will not. They were just "Back up" in-case I could not fit my tires on stock suspension
snowcatxx87
Calgary
1290SDR EVO / Tiger 900RP / 300cc Grom / Surron
Do you not use the bed at all? When you load up the back you will be blinding everyone and also suspension geometry will be way out of wack. Trucks aren't level on purpose.
Phillipjon
2018 RAM 3500 - 1996 F250 - 2012 Ford Flex
I have a 1" kit for sale, brand new never installed
Lhaddix27
Leanna
Wv
23 ford maverick
What is the brand. For these that are bolt on ? I found some at rough country but it requires the strut to be decompressed
Jman79
North East, USA
Honda Odessey, Ford Maverick 🤞MY24
Lol, very good approach. May also help traction for AWD variants!
For a moment I considered a leveling kit to give me all around extra clearance. Most applicable for when driving around my property for yard duty and yard waste center runs. Tad bit more room to navigate slopes and bumps.
Then I thought, wait, what pros of factory font to back slope would I be negating. Your post hits one. What about when I really drop decent weight in the back. Plans to make use of the 4x8 abilities etc. Nose extra high and tail down, then I'll look like I'm driving a boat home from HD.
Ford Maverick Leveling kit options??? download (1)
I'll just stick to factory and spend my $$$ else where.
wax87
Stuart
Dallas South
2004 Avalon
Then I thought, wait, what pros of factory font to back slope would I be negating. Your post hits one. What about when I really drop decent weight in the back. Plans to make use of the 4x8 abilities etc. Then I'll look like I'm driving a boat home from HD. I'll just stick to factory and spend my $$$ else where.
Just trying to help a brother out man! LOL
