level vs lift spring
FERALMAVERICK
Brent
2025 maverick tremor
im on the fence about weather to just get a level puck for the front of my 25 tremor or do i get the eibach springs and lift the whole truck . im planing either a 255/65-17 or 245/70-17 tire and i dont haul or tow much and if i do it not for long distance's or i use the full size truck . i daily drive this and and it gets some trails , for bike riding or hiking . i have a full blown offroad/overland rig to do more crazy.
looking for opinions, pics , ideas
Cancunbadlands
Cancun
Cancun
245/65R17 or 235/70R17 is the biggest size you can go without a lift needed
710-oil-614
Cal
2025 Hybrid AWD Lariat
If doing the springs I would get a suspension kit from FlatOut Suspensions and avoid Eibach.
matmondro
Mathieu
Vassar, MI
I did the Rough Country level kit on my FX4. No complaints whatsoever. Install was easy. I went up to 235/70-17 tires. For less than $100 for the level I think it's a pretty good value.
Ford Maverick level vs lift spring 20250122_163933
Ford Maverick level vs lift spring 20250726_190346
SubtlySeismic
Don
Houston, TX
2024 Maverick XLT Tremor
I've been making the same considerations as you for my 2024 tremor.
I assume this is the spring lift you reference:
Eibach Tremor Spring Lift
I will probably go with this once my stock wildpeaks wear out and put 245/70R17 tires with it. That should give a couple extra inches of clearnace for recreational activities. I love the way my stock tremor rides, so hoping this is mild enough not to change it too much since this is my daily driver as well.
FERALMAVERICK
FERALMAVERICK
Brent
YEP THATS THE SPRINGS IM LOOKING AT , THATS ALOT OF WHY IM TOSSED ON DO I JUST SPACER AND KEEP THE "SAME "RIDE ,ALSO THE CLEARANCE FOR THE BIGGER TIRE AND REDUCE THE RAKE
Alpinefire
Paul
Quebec
2023 Ford Maverick XLT Tremor
I just did the Eibach Springs and moved up to 245/70R17 ATs. On my 23 Tremor. Ride quality is very similar. Steering is a bit more sluggish. Had the 2 front cv axles and rear sway bar links replaced under warranty. All of which were making noise before the lift and tires.
FERALMAVERICK
FERALMAVERICK
Brent
do you have pictures before and after ?
Marty
2026 Ford Maverick Tremor
Ok lift kit for more ground clearance, I get it.
Leveling kit ?
My stock 2024 sits level even with a light 400 load in the bed.
I don’t get the leveling kit option.
What am I missing ?
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
You better check the weather first whether or not you should do this.....
Ford Maverick level vs lift spring {filename}
FERALMAVERICK
FERALMAVERICK
Brent
Leveling kit ?
What am I missing ?
MINE AND ALOT OF THEM HAVE A RAKE TO THEM MY REAR SITS ABOUT AN INCH AND HALF TALLER . A LEVEL PUCK IN THE FRONT WILL MAKE IT MORE EVEN
