Hyim
Henry
Ontario, Toronto
2022 Ford Maverick XL Sonic Silver
Had my LED strips installed couple weeks ago, a must for XL owners or even XLT owners who don’t have a light inside the bed. The factory lighting from 3rd brake light just isn’t enough especially if you have a tonneau cover on.
Ford Maverick LED strip bed lighting installed FD814584-7114-44CC-8856-29C0BBC7D034
Ford Maverick LED strip bed lighting installed ACC3B072-59C8-4421-9EAA-A247F099DB1F
I purchased two 6ft LED strips that came as a bundle, a switch was included. I used the factory pigtail that was provided and spliced the power and ground wires. A simple job but time consuming to tuck the wire and ensure that the mod would last.
Ford Maverick LED strip bed lighting installed 6F3F0A94-0BF8-4F00-805A-5F9D8F18C037
Ford Maverick LED strip bed lighting installed 1429FEEC-4305-4571-BB38-5561110C7B56
I removed the left rear cover (bin for those non-XL owners). Ran the LED wires thru the rubber grommet that was already on the vehicle.
Ford Maverick LED strip bed lighting installed 437AC103-64E7-48DD-B30F-86F792345B7E
Ford Maverick LED strip bed lighting installed C63E0987-189C-402A-B2BD-886F0A51B084
My LED were 6ft long so I had a few inches left over so I stuck them onto the front of the bed making a L Shape. Ran wires under the vehicle in front of spare tires. Took a bit of time to ensure the wires weren’t just hanging, secured all wiring to existing harness and electric taped all my wires as I didn’t want any water/mud/dirt/snow damage. Was able to sneak the switch between the bed and tailgate. Electric taped the switch completely and did a small cut out for the actually switch button to protrude out of the electric tape.
Ford Maverick LED strip bed lighting installed 2C8E6BB8-FBB7-45DC-AB65-AD006B21CA15
Ford Maverick LED strip bed lighting installed 7012C8F7-7052-4D21-B756-20026F42043B
It was the only spot I could reach with the provided wires I was giving from the LED strip, I could have extended the switch wire but got lazy. Overall I like the setup and pretty sure I won’t have any wire damage to come, hopefully these LED last. They're super bright, if I had the tonneau cover folded and lights on, you'd see me EVERYYTHING. Super excited to put this truck to use when camping season opens again.
FriscoTXJoe
2022 Maverick Lariat
Nice work!!! Post a link to the lights for those so inclined?
Hyim
Hyim
Henry
Ontario, Toronto
Ford Maverick LED strip bed lighting installed 446BBF42-1322-4ADA-BD36-79181B63519E
Got them from Amazon, was $39.99 CDN. Not USD. Make sure you get strips that are protected well. These strips had a thick protective rubber encasing the LED from water
akirk
Amanda
Ontario Canada
F-150 Quad Cab, XLT Maverick
Looks great! I have an XLT (well it's coming) and am thinking of doing this! Thanks for the pics! Great job!
snowcatxx87
Calgary
1290SDR EVO / Tiger 900RP / 300cc Grom / Surron
Even with the Lux pack, I just don't think the lights compare to this strip lighting. Can't wait to see how it looks in person, but I am betting I will be adding these as well.
Hyim
Hyim
Henry
Ontario, Toronto
They are extremely bright. Super happy with the LED quality, hopefully they last. Mainly worried about winter but currently they’re holding up good, the 3M tape that we’re attached to the LED are pretty good quality too, so that’s a bonus
snowcatxx87
Calgary
Yes I feel you on the -30, adhesives start to not adhere haha. Wicked post and thanks for the pics.
JSanchez
Jorge
Los Angeles
1996 Suburban C1500
Looks amazing, only bad thing is that my XLT will have the sliding tie down where that rubber grommets at. I’m sure there will be other places to run cables through though
Hyim
Hyim
Henry
Ontario, Toronto
should still be able to squeeze thru, the grommet is recessed a little so should have no problems with the sliding rail system. I plan on DIY rail system in spring. Too cold atm
gear1975
Winnipeg, Manitoba, Canada
2022 Maverick, 2020 Civic, 2006 Pathfinder
I'm doing this install once the weather improves for sure! The tonneau cover makes seeing in the bed at night nearly impossible.
I did the DIY rail system (pic below), and it's worked out fine so far. Great post and pics!
Ford Maverick LED strip bed lighting installed 1643224714181
Barracuda340
Abilene Tx
My LED bed lighting kit came in. Now I just need the large 4 wheeled accessory to install it.
Ford Maverick LED strip bed lighting installed 20220130_063805
Ford Maverick LED strip bed lighting installed Screenshot_20220124-091334_eBay
Mymaverick2021
Steveo
Hilo Hi
Someone else that installed the same lights said that you can cut them to length, There's a mark every couple of inches.
