Key will not turn in the ignition
Papadogo
Hola
Albuquerque, New Mexico
2022 Ford Maverick XLT
Yes, I’ve tried turning the steering wheel 180° in both directions with no result. I can’t move the gear changing knob to neutral.. The dash lights come on. But the key won’t turn and the truck won’t start.
Any suggestions?
RR - All the way
GA
Yes. It is a 2022 XLT hybrid
Truck "brain" may "think" the vehicle is not in park. Try putting it in N via the method given in the owner's manual if a vehicle is in park or a mode other that neutral and won't start and you want to get it on a tow truck. Return it to P and see if starts. Just a suggestion and may not work. If nothing else, you will know how to get in N to get it to a dealer.
sprcoop
AZ
2023 XL Hybrid, 66 Mustang Coupe, 2012 Focus DCT
Try a different key?
CurtisB
2023 Maverick XLT Hybrid
I had this same issue the first time I got into the truck.
Make sure the truck is in Park and the brake is on
Get out of the truck and double click it to lock
Wait 30 seconds and double click it to get in
Place foot on brake, insert key and turn it "all the way" clockwise
This should work. If not, I'm at a loss...................
Ford Motor Company
Official Ford Account
Dearborn, mi
Any suggestions?
Hi there – send a message to us with your VIN and approximate mileage, along with some more details about your situation. I’ll look into this for you. Thanks!
Bert Rooster
Albert
Rio Rancho, NM
97 Toyota T-100, 06 Jeep Liberty, 2018 Tiffin MH
Have you tried disconnecting the negative battery cable for a few minutes, then reconnect and truck should reset.
Papadogo
Hola
CG all the way! I was so excited to read your post because it was at least something I hadn’t tried. Much to my disappointment, when I lifted up the center panel and popped up the tab indicated on the instructions there’s nothing there. on the left side there’s a wiring harness, but there’s no manual parking brake override.
My steering wheel is not locked. My key won’t turn, and I cannot manually. Change the transmission from where it is into neutral j be
Mr Pibb
Vegas
2024 Lariat
Have you tried throwing a battery jumper on it?
Toy Truck
Paul
pickering on
2023 hybrid
That worked for the first week I got my truck.
