Is there a way to find the wifi MAC address
gman0025
Greg
2026 Ford Maverick
Is there a way to find the wifi MAC address of the 2026 Ford Maverick? I want to add it to my home network so I can updates.
scharris99
Daytona Beach
2025 Maverick XLT
If you have a fairly secure password, just enable new connections, then lock it back down after it’s in. Otherwise it is listed somewhere in the touchscreen settings.
GlennBeer
Glenn
Manteca, Ca
24 Maverick Hybrid Lariat, 04 SSR
If you connect the Mav’s wi-fi to your home’s access point, you should be able to login to the ap and see a list of all the devices attached to it. The info should include the Mav’s MAC address.
Yes.
It is in your screens listed.
Probably the same About Ford audio my shows it.
JJTech
Pennsylvania
2025 Maverick XLT, 2006 GMC Canyon
Note that, (at least on 2025+) I think in some cases it connects to WiFi networks with the TCU, and sometimes it connects via the APIM? So you would need to whitelist two separate MAC addresses.
I don't think there is any documented logic to if/when it will do one or the other or both. I've been meaning to look into it.
ETA: See also https://www.macheforum.com/site/threads/2-wifi-connections-which-does-what.9668/. The 2021 Mach-E is based on roughly the same FNV architecture as the 2025+ Mavericks, networking wise.
Pointyears
Richard
South Central PA
2025 Maverick Lariat, 2018 Mustang convertible, 2012 Harley Softail, 2024 Vita
With MAC spoofing being so easy to do, whitelisting every device is like peeing in the ocean to make it deeper...futile. A strong WPA3 password is all that's needed, along with updated firmware. If you can't update it or use WPA3, throw it in the trash.
