Is it THAT Simple - Tailgate cable too Long?
Old Man
Nebraska
2023 Lariat
Personally, I would of twisted it 360 degrees.
inthecabin
Andy
2021 Ranger Lariat FX4
Heard it, seen it, didn’t care and now a simple solution presented may create damage… WTF , really just do it or don’t… wow the speculation of worry warts astound me 😂.
Does anyone make slightly shorter cables for the bed? Seems like the issue is that the cables are a tad too long.
Mine hybrid was built in Oct 22 and til gate is damn near spot on with close to 1/32" high at hinge but I had anti theft hinge lock installed so that may be that 1/32". (?). Might check to see if new cables are correct. When was yours built?
Syntax Error
2023 Lariat Hybrid Carbonized Grey
I'd measure mine if I actually had my truck on hand. It's being built right now. ;)
Andrew1966
Andrew
WI
I had an issue where the cable would want to ride on top of metal plate holding the dampener end to the tailgate thus making the cable protrude through the crack between the tailgate and the box.
Here are photos of the fix. Heavy duty rubber band.
Ford Maverick Is it THAT Simple - Tailgate cable too Long? 3FB95B54-F6F0-437C-A281-3F301BAAC960
Ford Maverick Is it THAT Simple - Tailgate cable too Long? 1B5CE1D7-AF84-4C96-9D85-5438FB637C25
Ford Maverick Is it THAT Simple - Tailgate cable too Long? 18C99163-EC6E-47DD-AB2B-5B3EEAAC61F8
Tremor guy
Wes
Tennessee
23 maverick Tremor
I must be lucky my damper with the cables are spot on level
Benilla
Edmonton
2022 Build and yup one cable is definitely longer than the other
Gpp
Gil
Sanford nc
2022 ford maverick
I know ford has been using cables for tailgates about 60 years or more and its been known since the first set went on they weren’t the same leangth! But that was when trucks were used mainly for work ! Get over the length deal and drive it !
lostinacrowd
aaron
nh
Ack. I wish I had thought of / seen this. My 2022 is too long and the tailgate just barely touches the top of my trailer hitch. I forgot to move the gate to the higher position and now I have a scratch. My friend has a 2023 and his is for sure level not dropped. He won't trade cables with me for some reason ;). I'm going to twist them now. Thanks!
