canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
canuckford
Lou
Norton popped up and blocked the site on my PC. Said it had a password detection virus embedded.
You have to question Norton on this, what password detection are they talking about? what was the exact message Norton spit out?
canuckford
Lou
Norton popped up and said site blocked for a password detection virus, then ran a full scan and removed the virus. Since then I can access the actual link to the fuse box.
It's possible you got the virus from somewhere else, I put the URL through several virus scanning engines and no vendors had any hits.
Phimosis
Larry
Santa Clarita, CA
When I needed this info and googled “maverick fuse box”, this was the first site to come up in google’s results.
What I was interested in is finding out how much wattage I can run on a pure sine wave inverter from the 12v cigarette lighter outlet, since the built in 400w modified sine wave inverter is such garbage.
The diagram shows under hood fuse 71, “media bin power point” as a 20 amp Mcase fuse, good for 240 watts
The diagram also shows under hood fuse 83, “pickup-box power point” as a 20 amp Mcase fuse, good for an additional 240 watts.
I pulled the fuse box and verified that those slots are indeed 20 amp Mcase fuses and ordered some spares:
Ford Maverick Interactive fusebox / fuse diagram IMG_3852
In the bed outlet, I have an Etsy 12V plug in kit and I run a Bestek 300W pure sine wave inverter($35 on Amazon) to power my E-MTB charger. The MTB charger pulls 190-200 watts on a kill-a-watt and has not blown any fuses so far.
Ford Maverick Interactive fusebox / fuse diagram IMG_3850
Ford Maverick Interactive fusebox / fuse diagram IMG_3851
I use the in-cab 12v cigarette lighter port to run my radar detector (5 watts) and to charge my jackery explorer 600 (200 watt draw) via a 12v cigarette lighter outlet splitter with 14 gauge wire and 20 amp fuse.
Ford Maverick Interactive fusebox / fuse diagram IMG_3853
it’s not as elegant as changing out the 400 watt modified sine wave perverter that is running on a 60 amp fuse, but it does work.
Food for thought.
Escapologist
Niagara Region, ON
Thanks for the post, but whooo, counted 4 different fuse types, gonna make carrying spares complicated.
U: I'd like to buy fuses.
PartsCounter: Sure, what type and rating.
U: All of them.
Phimosis
Larry
Santa Clarita, CA
U: All of them.
I bought replacements for the Mcase-20 fuses and the pigtail included replacements for the AGC-20 fuse. What other fuse types are you seeing here that I’m not seeing?
The sine wave inverter has electronic switching that shuts off if the draw goes over 300w, but doesn’t blow a fuse. It does have a non-replaceable 40 amp fuse inside of the inverter case, in case of a catastrophic failure.
rtphokie
rtphokie
Tony
Raleigh, NC
2025 Maverick XLT
You appear to have done this in the past. How often have you needed a spare fuse?
After cleaning out my grandfather's and now my father's garages, I've adopted keep all but the spares I need on a regular basis at AceLowesDepot and auto parts at O'AdvanceZone.
Ranko Kohime
Ranko
2025 Maverick XLT
I wouldn't be a bit surprised if Norton did have a password detection virus.
mikeps1
Pullman WA USA
pnwdigital.net
2025 Maverick Lariat AWD Hybrid
