- First Name
- Anita
- Jul 16, 2025
- Suffolk, VA
- 2023 Maverick Hybrid Lariat Pkg, 2005 PT Cruiser GT Turbo Convertible
- Engine
- 2.5L Hybrid
I am currently attempting to install a set of Bling Lights Fog Lights on my truck and in my state the fog lights must turn off when the low beams do. If they are wired into a toggle switch, etc,,,, they will fail it on our annual state inspection. This is where I am having the issues.....my plan was to wire the new lights directly into the low beam light wire at the connector on the driver side headlight. I have googled all this and it has me a little scared. What I read was that if you wire directly into that wire it will damage the BCM. It spoke about having to install a 30/40 amp relay and the connect to the low beam....it said you can wire into the switch that came with the lights and use that as the relay.....spoke about locating it under the hood and leaving it in the on position to allow the fogs to work off the low beams. I am scared of damaging something if I try to do it the way I was which was wiring straight into the low beam wire....but I read on here where others have done it with no mention of having to use a relay. the light lights are 12v 55w. Any help/guidance would be greatly appreciated, along with pictures would be da bomb.....I am just worried because I know these hybrids are a beast of their own.....but I sure do love it!
Thanx so much.....Krooozn
