- Jan 17, 2022
- United States
- 2022 Ford Ranger Lariat Tremor
- Engine
- 2.0L EcoBoost
Any reason to keep them then?Damn!
They look better, brighter and more modern than incandescent bulbsAny reason to keep them then?
And you already have separate LED DRLs on the lariat - adding these too would probably just be overkillThey look better, brighter and more modern than incandescent bulbs
These don’t run as Drl on the lariat bc it HAS the signature led…only flash as a turn signal.And you already have separate LED DRLs on the lariat - adding these too would probably just be overkill
Yeah you were saying the reason to keep them on the lariat is because they're brighter, look better, etc. I was trying to agree and say that having the turn signal act as a drl on the lariat would be overkill anywayThese don’t run as Drl on the lariat bc it HAS the signature led…only flash as a turn signal.
Gotcha. My bad. LolYeah you were saying the reason to keep them on the lariat is because they're brighter, look better, etc. I was trying to agree and say that having the turn signal act as a drl on the lariat would be overkill anyway
You are probably right. Thanks for helping me see it in another perspective. Yes they do look more modern and sharpAnd you already have separate LED DRLs on the lariat - adding these too would probably just be overkill
I wish I had known these specifics before I purchased them… Oh well, they came finally and I installed them. My word they are bright. I guess ill have to live with themSwitchbacks do not work the same in Lariat without DRL wired to run when turn signals are off. They will just flash amber with turn signals and be off otherwise. I used the non Switchback on my Lariat for that reason. Also be sure to get the Standard socket not CK socket.
Need the brighter bulb against the led headlights tooNow if people would just use their damn blinkers when they turn that would go along way! I like the brighter bulb because these day so many people playing on their phones. I want them to know I am turning.
If you want to part with them, I'd take them off your hands. Lasfit does not ship to Canada.I wish I had known these specifics before I purchased them… Oh well, they came finally and I installed them. My word they are bright. I guess ill have to live with them
How do they look on lariat? Do you have pics/video I placed order about to cancelI wish I had known these specifics before I purchased them… Oh well, they came finally and I installed them. My word they are bright. I guess ill have to live with them
If you are getting them for the Lariat just get the amber, you don't need to switchback because you already have DRL across the top of your headlight assembly. They are super bright and install in a snap. The XL and XLT use the turn signal as the DRL, so the switchback works with them.How do they look on lariat? Do you have pics/video I placed order about to cancel
