Hyper Flash Update
LeersMav
Maximus GP
Orange County, CA
Well when you buy the lasfit bulbs that are plug and play, you don't need to know how to put resisters into any vehicle lol. I'm now 100% LEDs and no resisters needed, no hyperflash
I installed all the lasfit LEDs on my Lariat just tonight. Quality of these LED lights are very good. No hyper flashing. What a difference in lighting. Especially when backing up. The brightness really enhances the backup camera. The 3rd light really brightens the bed. I have a XLT and a Lariat. I posted pictures to show a comparison. The Lariat is on the right from behind. From the front it’s pretty obvious which one has the LED. Too bright for a camera, pretty much just a glare.
Same here. Did not want to mess with hyperflash and resistors. Plus, the Lariat will not take front turn signal switchbacks because of the DRL (LasFit states this in the website).
Yes LasFit is much more expensive ($25 vs $45-$50) than Alla, or any others. But then no resistors needed, no alterations needed, just plug-n-play.
And true, to each is own ...... So if you want the less expensive LEDs, make sure to buy the resistors at the same time. Agree: different strokes .........
Benilla
Edmonton
The LASFIT front turn signal and rear break/turn signal canbus ready are bright and do not cause dash signal or any hyperflashing. I had originally purchased the Alla rear break/turn signal bulbs, but it did require resistors. While I was able to install them, I just didn’t like the fact that they got so hot. So, I got the LASFIT and was able to remove the resistors and just go with the canbus ready bulbs.
I have found the Alla 3rd brake light and cargo lights actually brighter than the LASFIT. But not substantially so.
Do you have a link to the rear break/turn signal bulbs from Lasfit please?
OTACORB
DAB
Central, Louisiana
