Hyper Flash and Taillights
OTACORB
DAB
Central, Louisiana
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
I'm afraid that a place like Hawaii, error free bulbs will be too warm always. Resistors is likely your only way.
LeersMav
Maximus GP
Orange County, CA
According to LasFit, if you get the hyperflash with the front TS, then just turn the bulb around (remove and reinstall 180's). Happened to me when I installed the RF TS. Once switched, it worked fine.
I just use the Alla's for single filament bulb replacements, while I use the very expensive LasFit WT21s so I don't have to fiddle installing resistors.
Amazon has the 10% coupon (discount) available for all LasFit LEDs I ordered ...... but WOW, spending $140 on 3 sets of LEDs is quite expensive, but hey, whatever, it's just money ...... sigh!!!
Naranjita
NAH-RON-EE-TAH
I don't know why other Lariats are having problems. I have no hyperflash, with or without headlights on. I made a video below. This is with Lasfit 4257 NA Amber Only No Switchback LED Canbus Error Free Bulbs up front and Alla Lighting Xenon White WT21/7W Brake/Tail/Signal LED Bulbs in the rear (top and bottom, each side - 4 total).
I installed the Lasfit, and drove around for a day. Then installed the Allas the next day. Is it the order I installed them and not at the same time the difference? Are others using the switchbacks up front or the red in the rear? Are they not using the two stage Alla lights in the rear? I have no idea.
But I have not had one error or hyperflash since I installed them. It's been weeks now.
Still no hyperflash after 20 months and 50,000 miles. Although, I did have to replace one of the Alla bulbs in the driver side upper taillight at ~45k miles. It did hyperflash when it 'burned out', but stopped hyperflashing once I put the replacement Alla bulb in.
