- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Not really too complicated.ok, so when the Ford app say "Battery Save Mode" (BSM) it is due to the voltage at the 12V, or a combination of the voltages from both HVB and 12V?
My truck went into BSM yesterday when I was doing a bunch of stuff inside the cabin, and doors were open and closed started it about 6 times without driving, etc. Probably used a few amps all together. So I charged the 12V using a smart 3 stage charger for a few hours. As soon as I disconnect the charger, the battery showed 13.4v, and this morning after sitting all night, was at 12.4v (I did not lock the doors) 12.4v isn't dead, but probably about 60% charged?
At one point today, I had full access with the Ford app, then it dropped back to BSM.
I've poured over a bunch of DSM and saver mode thread here, and have figured out that its a very complicated subject why these trucks go to saver mode.
I know this is the original factory battery in the truck because I bought it from original owner, and he says it's the one that came new. I've already ordered a new AGM H4 for the truck. Maybe that will be the answer?
Thanks to all of you for your input and comments.
BSM:
Kicks in if startup voltage is seen at 12.1 or less (system isn't fooled by higher voltage after a drive, because it knows that's not a valid reading).
May not even be noticed as lights turn off sooner and sooner as voltage drops - until so soon it effects you.
Also kicks in for 25/26 if truck not started for 5 days.
DSM:
Kicks in if voltage drops to 9.5V, truck not started for 14 days (336 hrs), or SOC% drops below 40%.
May not be noticed if you don't use Ford app, since it merely disables the modem to stop hourly pings to keep the network up, which allows remote functions.
None of that on it's own indicates a bad battery by itself.
It's all done to conserve the battery for the next start - system has no idea how long that may be.
But it may give a clue what's going on.
Lights going off sooner - typical issue of undercharged - advice given above if a newer battery.
Receive Ford app alert of BSM and another for DSM some night when you had not been getting them.
Probably having an intermittent parasitic drain event, or battery already low and you left cabin light on that wasn't auto-turned off quick enough.
So yours held at 12.4V after a decent drain event - did the same thing to me after some maintenance with doors open/closed constantly.
The BMS system will be very motivated to provide higher charging amps until it feels recovered. It tracks Ah charging/discharging by the system, and will attempt to get them closer to equal.
Keep locking up at night - if you haven't yet the BMS Relearn didn't happen yet, to see the higher charge, and adjust it's internal SOC% figure.
