Hybrid Synthetic Engine Noise. Can volume be reduced?
The Real Maverick
Jack
The Maverick has this.
Not exactly.
Maverick has a sound speaker about the size of a 1 lb. Coffee can behind the driver's side FRONT bumper. Where a fog light should go. And nothing in the rear. Which is one reason it is a little loud, so the "clink clink clink" sound, makes it to the rear.
dochawk
doc
Las Vegas
Sounds like whales mating.
cetaphobe!
Anyway, if it's an 8 ohm speaker, sticking a 1 ohm power resistor with a fifth the wattage rating of the speaker in series would reduce but not eliminate the volume. Or even two.
dochawk
doc
Las Vegas
while I'm thinking about it, the power across the speaker would be reduced by 21% for one hot, and by 36% for two ohms .
The Hyundai Tuscon hybrid has a horrendous reverse noise. Sounds like whales mating. (Rather what I would expect that to sound like, lol)
[/QUOTE
Like this?
  • Haha
Reactions: Dad
Hmmm, doesn't sound that awful, unless her phone just didn't give justice to the volume.
Or they changed it for 23/24 MY.
Dad
Awfully close! LOL.
Benilla
Edmonton
What blows my mind is these manufacturers have an opportunity to come up with ANY sound and this is what they choose. I don't actually have an issue w/ the backup sound of the Maverick but that fake engine noise sounds like a 7th grader learning how to play a horn.
It's not like there isn't a whackload of data of engine sounds that guys actually like. Why not model after one of those?
The Real Maverick
Jack
Because there are rules, testing, and years of data that this is appropriate.
You need to know what you are hearing, not just simply hear something random.
Benilla
Edmonton
I don't mean any random sound. I thought I didn't need to specify esp when I go into the specific sound and situation I'm referring to on the Maverick but MTC surprising me yet again
ricklee4570
Rick
Virginia
2025 Ford Maverick Hybrid
Mine sounds like a growling noise when turning at slow speeds. Good luck if you ever have an engine issue or driveline issue trying to ascertain the problem with all the weird sounds the front bumper speaker is omitting.
