Hybrid Fuel Efficiency 2023 vs 2024
Mightybeast
Adam
Oklahoma
Maverick hybrid
Hello, I have 2 Maverick's 2023 XKT and 2024 XL. I Own then since day one. Both of them got bed cover and they Hybrids. On XL I installed bronco wheels instead of stock steel. Also I installed mud flaps, diferent type ltho. On 2023 it's weather tech and on 2024 it's Mabett. In my opinion Mabett got a bit better quantity and more flexible. But also they are 1-2 inch longer. I so keep a note on fuel consumption via app, and it's actual mpg. Unfortunatelly it looks like 2023 xlt is more efficient than 2024. With set up that I have. Now my question is any bidy experiencing same issue? I used both trucks to get to worm. So, consistency there. While my 2023 give me on average about 43mpg, my 2023 only 41mpg. Any thoughts?
Ford Maverick Hybrid Fuel Efficiency 2023 vs 2024 Screenshot_2025-02-23-17-27-36-98_2e45c52e5e3520e10fb581209da03ca5
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Does the same person drive both trucks? I ask because different drivers could easily explain the difference.
Flesherton ON
2024 Ford Maverick XLT Hybrid
Are the Bronco wheels and tires the same overall diameter and width as on the other truck? Are you running the same psi on both trucks? Any difference in width, diameter or psi will make a small difference. More likely the conditions you drove under. If you happened to have a bit of headwind or the temperature was different when you did your comparisons, that too could explain the difference
ShadowBlack XL440
Robert
Northern Ohio
Weight difference in the Bronco wheels and tires? Heavier?
Mightybeast
Mightybeast
Adam
Oklahoma
Maverick hybrid
Wheels/tires are the same. They interchangeable with Bronco.
Mightybeast
Mightybeast
Adam
Oklahoma
Maverick hybrid
Big Bend Bronco
- factory wheel + tire = 58.25 lbs
- factory aluminum wheel: 23.25 lbs
- wheel offset: 55 mm
Ford Maverick Hybrid Fuel Efficiency 2023 vs 2024 PXL_20230617_155659379
