Hybrid Engine Heater
GPSMan
Many
There are other options! The pump type coolant system heaters work great. That's what I'm using on my Ranger. Stick on pad heaters tend to overheat, and a malfunctioning one can actually boil your oil.
Or catch something on fire.
(I've heard)
GPSMan
Many
I had a 400 watt OEM engine block heater on my 2005 Hybrid Escape.
In a garage or carport with no wind, there was zero temperature gain after 4 hours. And like stated above, 2 hours was plenty for most situations. I put it on a timer. No sense in paying for extra electricity. Equilibrium was around 90 to 100°F IIRC, but it would get to 70 or 80 in about 2 hours.
(from zero or single digit F)
Stang89
Kevin
1989 Mustang, 2014 CMax
I live in the Canadian prairies, we commonly see -30c/-22f in winter. It’s common place to plug in all day at work and all night at home. Other than replacing the plug occasionally I can’t remember the last time I’ve heard someone need to replace the actual block heater. I sure hope the block heater in my Maverick lasts like all the other ones in the vehicles I’ve driven for the past 40 years.
KDay
Toronto, Canada
2023 Maverick XLT Hybrid
FWIW, block heater seems to draw ~415w. ('23 XLT Hybrid... though I can't imagine it would be any different on other versions/years).
Ford Maverick Hybrid Engine Heater 20231128_203029
Rokan
Chicago
Ford Ranger
Part number JX6Z6A051D
Best I can find is about $84 before shipping. Anyone install it themselves? Trying to find where to screw it in but empty handed.
Ford wants like $120 for the power harness alone. Anyone who can wire an outlet knows it's like $20 at the depot.
Can it be a DIY job, yes. Should you attempt it if you have little or no experience working on cars, probably not. First you need to drain the coolant as that’s where the heating element sits and you need to refil it and bleed/burp the system. Second it’s not an easy spot to get to without dropping some exhaust components. There’s a plug there that you need to remove that was factory installed and screw in the block heater.
Rokan
Chicago
Ford Ranger
If it's like anything else in modern wire harnesses there is likely a computer module that tells it when to turn on and off. That's why they want $120.
No module just a heating element that powers on once plugged into 110 outlet. However it is not an easy install. One key aspect if you’re operating the block heater do not leave it plugged in overnight it’s not reccomended even by ford. It reaches a maximum operating temperature in 3 hours. You’re suppose to plug it one a couple hours for example before you drive in harsh climate. I personally use a wall outlet that the cord is plugged in that has a timer I run through WiFi. I leave my house for work 6am so it turns on at 3:30 am and shuts off 6am on the dot. By the time I leave my subdivision it’s blowing warm air 👍.
