Hitch Carrier
Bigcanoe
Moncure, nc
2025 Maverick XLT, 2022 Toyota Rav4 Hybrid
Hi, I am in the market for a Maverick. I am mostly interested in the hybrid. I noted that the turbo and the hybrid have different tow capacity. The hybrid says 2000 and the turbo says 4000. But what if all I want to do is carry a motorcycle on the hitch carrier? Why would that capacity be different? Do these models have the same body, and suspension and brakes? Can I carry 400 on the hitch on either model?
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Sounds correct to me, same tongue weight, same hitch.
https://www.ford.com/cmslibs/conten...ides/2022_Ford_Maverick_Towing_Info_Oct20.pdf
AF Blue
US
NA
10% of Max Tow is what I see listed:
2023 FORD RV & TRAILER TOWING GUIDE
Compare Maverick Hybrid to Transit and Bronco Sport limits (Page 44).
So... there is legality and capability .... you'd probably be fine with 400lbs on the hybrid, but 200lbs is "safe".
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
Specific to your question, "Do these models have the same body, and suspension and brakes?"
All hybrids are Front Wheel Drive (1st image), and most EcoBoost models are All Wheel Drive (2nd image) with a different rear suspension.
Ford Maverick Hitch Carrier FWD
Ford Maverick Hitch Carrier AWD
Hot Runr Guy
West Chicago, IL
I have a 2.0 with the 4K tow package, and was surprised at the amount of "sag" with 250# on the ball (tongue weight). You may need to add some suspension assist to carry 400#, considering the additional setback.
HRG
Bigcanoe
Moncure, nc
Air bags maybe...ty!
Cam
ABQ
Honda
For the most part you would be fine, the primary component driving the rating difference is the ECVT transmission in the hybrid. I agree with the above comments about the rear suspension and need for extra support if maxing out hitch tongue weight. Frame wise you should be fine.
