Gotta ask Question to dump ford Pass
DavidLs
Texas `
Ranger/23 and 24 Mave hybrids
Hello Guys
I Had to activate the Ford Pass Account did the Pairing with my Mav as soon as I got the reward points I got the Bed Liner. IM done with the Modem and The App and Ford Pass now. I want to cancelled it all at this point. I want to unpaire it with my Mav and deactivate the modum. IF so any Issues and how did you do it. I got what I wanted and need to let it go.Thanks
TarpDogg
Nathan
Ohio
2022 Maverick Hybrid XLT
Short of removing the modem from the truck, which I doubt is an easy process, the only thing you can do is simply delete the app from your phone and ignore the fact that it still exists. You probably don't want to take it out of the truck even if you can, especially if you want to resell it in some years down the road. The other thing that it does is send check engine and error codes back to Ford. That way when you pull up to a dealership that knows what they are doing, they can immediately see all codes or check engine lights that you've had. Yes, Big Brother is watching and I don't like it any more than the next guy. Maybe someone on here has successfully disabled it and they can chime in.
bbhaag
Upposedly removing fuse #11 from the panel will cut power to the telemetry control module and nothing else. I've not done it my self but it seems like an easy thing to test. If it doesn't work you just put the fuse back in.
Here is a diagram layout I found done by a member here.
Ford Maverick Gotta ask Question to dump ford Pass fuse panel layout
wax87
Stuart
Dallas South
2004 Avalon
Wait, so if the codes are already in Ford's knowledge base, why have some of these guys been charged a $200 diagnostic fee? Especially if the diagnostic was wrong?
Think of it a a translation fee to "suckerease" dialect????
TarpDogg
Nathan
Ohio
That's a great question! The three dealerships I've taken my Maverick to have not charged that fee (Warranty I assume). Two of them are good with that system I mentioned, one has no clue. Needless to say, I will not be going back to the clueless dealership. And yes, they already have the codes in their system and can see them without you even needing to go to the dealership.
wax87
Stuart
Dallas South
2004 Avalon
I was thinking about this Post when I asked the question:
Hybrid violently shakes under load
TarpDogg
Nathan
Ohio
The only problem is, if your system isn't logging an error then there's nothing for the dealership to see on their end. Basically your Maverick thinks it's running normally so nothing is sent to their servers indicating otherwise. Maybe the "diagnostic fee" is the joyride they take to see if they can replicate the issue. That's billable time but should still be covered under warranty and be no charge for you.
Ozarkbeard
Hello Guys
In addition to unplugging fuse# 11 in the cab fuse panel (not under the hood), remove the VIN from your Ford account and delete the app's data. Then, uninstall the Ford Pass app from your mobile device(s).
DavidLs
DavidLs
Texas `
Thanks For Responding. I really was just looking for a way to just Turn the Modem off with a software
Solution. Delating the app is fine but I really want to just turn the modem off. My Bad Sorrry
Tiger Dude
Skip
Louisiana USA
2023 XL
p 377 in my owner's manual
WHAT IS A CONNECTED
VEHICLE
A connected vehicle has technology that
allows your vehicle to connect to a mobile
network and for you to access a range of
features. When used in conjunction with
the FordPass app, it could allow you to
monitor and control your vehicle further,
for example checking the tire pressures,
and the vehicle location. For additional
information, refer to the local Ford website.
CONNECTED VEHICLE
REQUIREMENTS
Connected service and related feature
functionality requires a compatible vehicle
network.
Some remote features require additional
service activation. Log in to your Ford
account for details. Some restrictions, third
party terms and message or data rates
may apply.
CONNECTED VEHICLE
LIMITATIONS
Evolving technology, cellular networks, or
regulations could affect functionality and
availability, or continued provision of some
features. These changes could even stop
some features from functioning.
CONNECTING THE VEHICLE TO
A MOBILE NETWORK
WHAT IS THE MODEM
The modem allows access to a
range of features built into your
vehicle.
ENABLING AND DISABLING THE
MODEM
1. Press Settings.
2. Press FordPass Connect.
3. Press Connectivity Settings.
4. Switch connectivity features on or off.
CONNECTING FORDPASS TO THE
MODEM
1. Make sure that the modem is enabled
using the vehicle settings menu.
2. Open the FordPass app on your device
and log in.
3. Add your vehicle or select your vehicle
if already added.
4. Select the option to activate your
vehicle.
5. Make sure that the name on the screen
matches the name shown in your
FordPass account.
6. Confirm that FordPass account is
connected to the modem.
zach57x
FL
2022 Maverick XLT
You can unplug the modem it is a black box behind the rear seats
