Got a message today: Remote features disabled to preserve battery
Grand Nat.
NYC/ L.I
Schwinn Stingray
Your battery is below capacity that's why you received that message. Hybrids an ego boost have the same battery management system. Do what the instruction say drive the heck out of it and while you're at it when you get home recharge your battery with a separate charger just don't connect the negative side of the charger to the battery but to the chassis ground instead.
Packer Bill
South Dakota
Ford's BMS stinks...it ruins batteries. Meanwhile I use a battery tender to prolong the life of my battery.
Ozarkbeard
Get a battery tender and use it. Connect it under the hood at the Jump/charge posts. NEVER connect a charger or jump to the battery under the seat.
RTFM, or one of thousands of posts on this forum about the problem.
TheSEARCH
ford
You sure on not connecting a charger to the battery itself under the seat. I know where the jump points are under the hood. Thats the best place FOR SURE?? I may connect charger in another day if I keep losing my dome lights and ford pass app.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
I hook my battery maintainer to the battery, but in theory you could damage the battery monitoring sensor that is located near the battery. Thankfully I have not had to do it since last February, but it does get lowish. There is no reason why there should be an issue unless you pump too much voltage into the battery, or if you connect it improperly.
To be honest I don't even know if it charges the battery if you hook it up under the hood, my smart maintainer never shows full charge if I do it that way. Best as I can tell those posts are only for jump starting the system if you have a dead battery.
Clarence Roller
Clarence
Lima, Ohio
22 Maverick, hybrid, 1st edition
I hooked my battery maintainer to the positive terminal and the negative to the car side of the BMS that is on the negative terminal. I've got a battery monitor hooked across the terminals and I've never seen the State of Charge above 77%.
Never had this problem with my 64 Galaxie 500, 390, four speed. Want it back!
glider
So Cal
2002 4runner 2019 Honda civic
It's like a plug-in. Ford should just make a battery maintainer standard equipment and a place to plug it in.
Never had this problem with my "40 Ford woodie. You could always push start it. Didn't really need a battery.
BlueSpec1
Gene
I use the jump post when I charge the battery.
It looks to be a piece of busbar that bolts into the High Current Battery Junction Box.
Ford Maverick Got a message today: Remote features disabled to preserve battery High Current BJB-1 - FordBossM
Ford Maverick Got a message today: Remote features disabled to preserve battery High Current BJB-4 - FordBossM
Ford Maverick Got a message today: Remote features disabled to preserve battery 2.5L HEV Charging System
Bill K
William
Maine
2023 Maverick
Take it to your Ford dealer next week. They will check your original battery and replace it. Crappy original battery.
Matso
2011 Mustang GT Premium
Don't even bother taking it to the dealer. They will likely tell you the battery needs replaced but alas, yes there are no batteries today. That T4 series has been on backorder since last I checked.
