Gas pump keeps shutting off
wb1957
wb1957
William
2024 XLT Maverick Hybrid
Try holding that collar back towards the handle. Some don't seem to fit well to the Maverick gas fill collar.
Tried moving nozzle all around, thanks for your responce
wb1957
wb1957
William
I had that happen after rear shocks were remounted on a suspension upgrade on my class C. The shop accidentally crushed one of the evap lines going to canister. I found the problem when I got home from trip - took.it back tobthe shop and they fixed it. Problem solved.
All this to say the evap system and canister could be looked at. I've heard that folks who habitually "top off" at every fill up can flood or clog the canister/lined and they are only designed to handle vapors.
Hope it was just the staions you chose!!
Thank you KathyG. safe travels
wb1957
wb1957
William
If you drive down lots of dirt roads the evap canister can suck up dirt when it vents. There is a kit from Ford you can buy to attach a hose to the vent port and place it where it is less likely to do that. We used to go a step further for our customers, farmers and ranchers, by adding a filter to the end of the hose. That always solved the issue for them.
And then like some of you have discovered there are just some pumps that can have issues and not want to work correctly.
Thank you. No dirt roads where I drive. Only 2k on the truck since I bought it in May. Appreciate your input.
wb1957
wb1957
William
The same happened to me twice on the same gas station, I still go to that place but I pick a different pump, according to someone there it could be old filter causing the problem, been two years going to the same place and no more problems.
I'm hoping the same for me Cyber Orange Guy. Thanks
wb1957
wb1957
William
Actually this is exactly what happened when I would overfill another vehicle I had. I was told to stop filling once it's clicked off. I forgot them fix but then dealership did not charge. I think they did it under warranty which you should still have under 36k miles
My previous truck was a used Chevy and I had to take the cannister off and blow it out, a lot of dirt road came out of it. An easy job and it worked fine after that. Thank you tcotti2003.
wb1957
wb1957
William
So, I went on a trip to Ga and back and filled my tank 5 times and at only one station did the pump not shut off early! 3 times i heard a suction sound when I inserted the nozzle, and the pump would always shut off and then spit some back out! I'm home now and just filled my tank again it kept shutting off.
I called my Dealer to ask about the problem and was told "well it shows here that the tank is full."
Anyway, I was told before I get fuel again to make an appointment and bring it up so we can experience the issue. I tried all the suggestions on this forum thank you. Don't like the spitting it back out crap!
You could always post a video of it happening. It isn't hard.
Most modern cell phones have a sealed battery no possibility of it explosion from your cell phone.
FishR_anger
Midwest
2024 ranger raptor 2025 maverick
Ford Maverick Gas pump keeps shutting off 1000005741
I have had issues in the past with my Fords when they switched to the capless system and 💯 had the same shut off issues. Later found out it is the pumps and I have watched out ever since when I grab a pump nozzle. If they are using a two piece nozzle and the end comes off it still pumps gas so the stations don't care. However the Ford needs that piece to work. I found an image online that shows this missing piece. If it's missing guaranteed to give you grief.
wb1957
wb1957
William
I took the "little fellow" to the dealer, they replaced the Fuel vapor vent valve. I'm expecting the problem to be fixed. Thank you, Dorian Ford.
wb1957
wb1957
William
So the last two times I tried to fill the gas tank the pump kept shutting off. Took quite a while to refill the tank. I tried moving the handle all around the inlet but nothing worked! I've gotten gas 5 times now since I bought it. I have never tried to add additional gas after the pump shuts off. So the vent is not clogged or even dirty. Anyone had similar issues trying to gas up? Although the last two stations weren't my usual stations but that can't be it. Anybody?
Update:
Try putting nozzle into truck at the closet to fender possible mine is sensitive to nozzle being too vertical. A problem on some pumps with the nozzle having to be inserted too far in to get vapor collection cup to activate pump.
wb1957
wb1957
William
Update:
another update: after the dealer changing the Fuel vapor vent valve the problem still exists!
Talked to an old buddy today who has a 2023 Maverick and he hasn't had an issue with the pump
shutting off. I'm going to where he gets gas next time I need it.
rognus
Roger
Northern Nevada
2025 Ford Maverick XLT Hybrid AWD, Subaru Impreza
Did you ever figure out this problem?
wb1957
wb1957
William
