FYI, OBDLink EX $40.77 shipped
ubiquityman
Maverick Lariat
I ordered a OBDLink EX today. Cost $40.77 shipped. If you order directly from their website and use coupon code RICARDOS, you'll get 30% off the order. They also did not charge tax for my state, whereas Amazon would have.
https://www.obdlink.com/products/obdlink-ex/
Kingpin003
Ryan
WA
2024 Maverick Lariat - Azure Gray
Thanks for the link. Picked one up.
Baloo
Michael
Indianapolis Indiana
Got mine off Amazon cheaper.
Baloo
Michael
It's currently $60 on Amazon -- what did you do to get it cheaper?
CTobd Elm327 USB Compatible with Forscan Software Obd2 Adapter for Ford F150 F250 Lincoln Mazda Mercury Code Reader Vehicle Scanner Diagnostic Programmer Tool MS HS CAN Switch https://a.co/d/f2sNEH7
A.Bursell
Stanwood, WA
In fairness, that's not an OBDLink EX. It might work, but it's not the same as what's in this thread. Might as well compare to one you can get for $1.99 on Alibaba.
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
That one has a manual switch between HS CAN and the MS CAN. The OBDLink EX has a software switch between HS and MS and is one of two scanners officially recommended by FORScan.
ubiquityman
ubiquityman
Maverick Lariat
I'm all for cheaper, but I don't believe the two are functionally identical.
OBDLINK EX does automatic datalink baud switching:
* Electronic MS-CAN/HS-CAN switch allows FORScan to access all CAN buses simultaneously and enables advanced functions not possible with “toggle switch” adapters
* Maximum throughput: up to 20 times faster than “toggle switch” adapters
Also, there is a benefit of strength-in-numbers with the OBDLINK EX as compatibility issues are typically more quickly resolved on higher volume products.
mcluvin
CR-V
The RICARDOS discount code still works. And the ELM327 adapters are hot garbage.
Packer Bill
South Dakota
Thanks for the code...just ordered one today!
Justin says...
Justin
NC
'22 Ranger XLT
I already have a generic one with a switch, so I'm trying to figure out if this would be worth it to me. Has anyone switched? Is it worth it?
BRTN
Bristol TN
2022 Maverick XLT
Thanks for the code. Ordered it the other day, and received it today. It was actually delivered by Amazon.
