FX4 AWD shorter than 2wd hybrid
jtpc2021
Oklahoma
Black truck is AWD FX4 lariat. Blue truck is First Edition hybrid lariat.
FX4 is surprisingly short.
Neither truck is mine, but cool to see them side by side.
Ford Maverick FX4 AWD shorter than 2wd hybrid F86122ED-805D-4FDF-B5FE-567523E04CD5
Maverickman74
Shane
Maui HI
Something is fishy here.
Jmav2152
Jamie
Cleveland, OH
Maybe lowered? Fx4 should absolutely have the most ground clearance and be taller.
Not necessarily. The FX4 doesn't inherently have any extra ground clearance unless you get the optional wheels where the extra height comes from the 235/65R17 tires.
I think the angle is playing some in favor of the hybrid. And the AWD is gonna be some 250 lbs heavier.
jtpc2021
jtpc2021
Oklahoma
The FX4 had nothing but one wooden board in the bed. The first maverick i saw at the dealer was also an FX4 and I thought it seemed short at the time. Pretty sure it has no height advantage over my XLT hybrid (which isn’t in the photo). Maybe someone else can witness them in person and give their 2 cents, but the two FX4 mavericks i’ve seen appeared shorter to me.
Mabcim
Rochester, NY
Looks like the black one has a stubby antenna. So likely the black one has other mods as well. Like maybe a lowering kit.
volksnuts
Katy,TX
Maverick Lariat HPR
The rear end of an AWD seems to be lower than the FWD
Since I recently swapped form a FWD to an AWD I noticed immediately that the wheel gap was smaller
I didn’t measure but the FWD always looked extra tall in the rear
Johnkn
MD
FWD tends to sit more tail-high... In addition, the height difference in 225 vs 235 tires is ~.35" , which can be easily overcome or tweaked with +- a few Lbs. of air pressure.
jtpc2021
jtpc2021
Oklahoma
It would be odd to lower an FX4 AWD
Ford Maverick FX4 AWD shorter than 2wd hybrid FE420670-1C1F-4351-A60B-5F2503546325
Shakesbear
J. R.
Maybe the blue one was lifted, or had larger tires put on ;)
jtpc2021
jtpc2021
Oklahoma
jtpc2021
jtpc2021
Oklahoma
Why is that?
My FX4 AWD will be lowered this week
Because FX4 is marketed as more off-road purposed. Higher ground clearance typically goes hand-in-hand with off-roaders.
Pretty sure this FX4 as well as the new one at the dealer I saw have not been lowered.
But yeah, my post is not to debate with you about your upcoming mod. Just a general statement as to why I doubt this FX4 is lowered.
