Fuel tank gauge accuracy? (Video)
Big Kahuna
WA
Best best is to never let your gas tank get this low. I was always told this is not good for the fuel pump if you do it regularly as when it gets low it can overheat because the fuel helps keep it cool.
Mavtremor24
Tony
Ohio
2024 maverick tremor 2024 space ford explorer timberline 2000 black svt contour
There's 2.5 gallons in the tank WHEN you reach MTE zero.
OK to run to the computed zero every week because of the reserve.
Computer zero is not the real zero.
Very true..I filled up earlier said 408 to E drove 42 Miles and it now reads 410 to empty sooo there's that..lmao
Big Kahuna
Big Kahuna
WA
The manual says there is extra but doesn't specify how much. " In addition, the fuel tank contains an empty reserve.The empty reserve is an unspecified amount of fuel that remains in the fuel tank when the fuel gauge indicates empty. See Fuel Tank Capacity . "
So the the 16.5 gallon capacity on the Ecoboost could be more like 17.5 gallons.
The Real Maverick
Jack
That's why I'm telling you what myself and others have done.
I have burned then refilled 16.5 gallons in a hybrid. Others have burned and refilled nearly 19 gallons in an E.B. Recommended or not, these are the physical capacities.
Big Kahuna
Big Kahuna
WA
Wow, so a 19 gallon tank, that’s crazy extra gas. Thank you for the additional input. Now everyone is going to start running their tanks to E 😀
The Real Maverick
Jack
I think you get it; but let's be sure.
"E" is the mark your gauge hits after you have burned 16.5 gallons.
Your engine stops running after you burn 18.x gallons.
dlivry7
IL
24 Mav Tremor
possibly 18.5, interesting.
my first tank after dealer fill and computer showing low fuel, past the miles left. 16 even (old fuel filler nozzle without the epa thingamajig)
2nd tank with epa device on nozzle 14.97 gallons
i'm going to push it a little further then
