Fuel efficiency towing trailer
Mvrck
E
I'm getting 24mpg highway pulling a 2000lb trailer on the highway with my hybrid. I also got 31mpg on a short 18 mile city trip which was pretty impressive.
pmcdonald387
Peter
Colorado
That trailer has a decent aero profile. That is a big help.
The headwinds barely notice your pop up. Put a 7'x7' sail on that trailer and it will be in the low teens probably.
He should have said a small polished brick(still better than any other truck) towing a big square box that weighs 3/4 of your brick.
Weight is a factor especially in Colorado with altitude and grades. But as I said the other trailer examples that showed pics of their campers, aero is huge. If you have a simple style nearly flat front trailer with a long tongue between the box and your tailgate it will catch air just like a sail. Not much you can do about it. A bed topper and a nose cone could add 1mpg each but would take a super long time to make it worth it. As others said atleast it gets good mpg while not towing. Next trailer purchase, if ever consider something with a sleeker front profile.
Thanks. The profile of mine is maybe not quite as aero as this one but it's new and rounded on the upper half specifically to better deflect wind. I expect there is still some resistance regardless of the design but agree aero is important.
pmcdonald387
Peter
Colorado
Speed. You need to talk about SPEED more than weight.
You'll get better MPG towing 4000 lbs of bricks or sand on a flatbed than you will get towing 2000 lbs of camping trailer. Wind drag is HUGE when towing something taller than your truck.
Also slow down 10 MPH and gain 5 MPG.
Your choice what makes you happier.
Thanks, I think there is a lot of truth to this.
Ranger5.0
Washington
F150, Lexus IS350 F Sport
I do a lot of towing regularly with my hybrid. 95% of that is on the highway. I keep the cruise control set to 65-67. With the small trailer and mower I get about 30mpg. With the open trailer I get 18-20. With the enclosed I get about 20.
Ford Maverick Fuel efficiency towing trailer IMG_20221031_082513
Ford Maverick Fuel efficiency towing trailer IMG_20221031_082522
Ford Maverick Fuel efficiency towing trailer IMG_20221031_082525
Ford Maverick Fuel efficiency towing trailer IMG_20221031_082529
GPSMan
Many
Have a similar enclosed trailer.
I get 20 MPG at 60 MPH.
At 9' tall the thing is like dragging a parachute. I have trailer brakes. But don't need to use them even on 5% downgrade.
Ford Maverick Fuel efficiency towing trailer 52066131-0936-4242-BCE6-D2C955CCFB16
pmcdonald387
Peter
Colorado
Thanks, that's really helpful.
pmcdonald387
Peter
Colorado
Loving this forum. Thanks everyone for your experience and guidance!
altomav
Keven
Huntsville, Alabama
Maverick, '71 GMC
I have zero towing experience with the Mav, I do think that when concerned with mpg most Mav owners aren't towing 90%of the time. If it's getting 30ish most of the time when not towing that should be better than a full sized truck.
I took a trip from Northern Alabama to Ontario Canada (Not towing) and back averaging nearly 28mpg, mostly highway miles. A few legs of the journey got 31.5 mpg. I did notice when using Premium fuel I got slightly better.
pmcdonald387
Peter
Colorado
Thanks, I completely agree with high quality gas and watching the speed makes all the difference. We just came back from a trip to the Midwest and was pleasantly surprised to see a pure gas /no ethanol option at the pumps. And not at exorbitantly high prices either. Unheard of in "progressive" Colorado in my experience.
RogueCheddar
BC Canada
22 XLT Lux EB 4K
Sykotyk
Ohio
With a hybrid in tow/Haul I average between 23 and 26mpg mostly highway. On streets was maybe 27 or 28. It you are driving in town just run normal and I've gotten 31-33 without issue.
GPSMan
Many
In the hybrid, tow/haul is going to be helpful for going uphill and for accelerating because it ups the engine RPM, basically giving you a lower gear ratio.
For downhill and flat or gentle roads I like normal.
I have found it gives you engine braking going downhill in any mode.
DeanR
colorado
Outback Tundra F250
When pulling a trailer only brag about gas mileage if you have a tail wind.
pmcdonald387
Peter
Colorado
That's really interesting, I hadn't thought about experimenting with changing drive modes too. Hopefully it's not a problem with the truck doing that on the fly.
