front end swap - 2025 onto 2022 Maverick?
logan78
logan
ohio
2022 ford maverick
has anybody front end swap a 2022 ford maverick with a 2025 ford maverick front end I consider doing it gust seeing if some one done it
DavesMav
FL
Not that I've seen, but it won't take all that much. Hood and fenders are unchanged, so you just need: headlights, grille and the upper/lower bumper covers. Headlights will likely be the biggest expense, then getting the upper bumper cover painted to match (unless you can find one in your color already) but I've started to see used lights and bumpers from 2025s come and go on eBay.
I'd figure for about $2k all-in you could do the swap. For some on here that's unfathomable, but a lot of us are starting to have our '22 models paid for, so that's a small price to pay for an all-new look especailly when a comparable replacement today is about $9k more, at least in my case.
Cancunbadlands
Cancun
Cancun
No one! But I think it's an easy swap
Cherokee
A 25 FE on a 22 Truck
or a 22 FE on a 25 truck ?
Then tell me what fore ?
Inquiring minds must know.
Sticks
Shawn
St. Louis
2025 headlights have different electrical connections I believe.
Correct.
The connectors are the same, but the pinouts (wire locations in the connectors) are different from 22-24. They also are slightly different from low trim (reflector) to high trim (projector). If one had access to the OEM wiring diagrams, it should be pretty simple to make an adapter harness.
Scott Asheville
Scott
Asheville, NC
Now I know who has been sneaking into my house at night and pasting dog faces atop beautiful models in all my magazines.
Cancunbadlands
Cancun
Cancun
Correct.
I know, 2018 VW Tiguan Comfortline with a low trim reflector headlight... I did the swap for a 2018 VW Tiguan Highline high trim with projector headlight... needed some harness and some software upgrade via VagCom... what I'm saying, it's possible
NM Bob
Las Cruces, NM
2024 Ford Maverick Lariat
My first thought was why would you? I had a choice between a 24 and 25 and went with the 24. I still can't get into the look of the 25 front end. It looks like a cheaply made matchbox car to me.
piwtrnr
Union City PA
Love the 25 front end, the 24 and older look like they got started and forgot to finish.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Have to admit the original front end looks like someone dug a shelved design from 2008 and slapped it on to save money. The headlights look they they were meant to have halogen bulbs for example.
