- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
So to be clear - you are a test case, if you don't mind that.Should I disconnect the battery during charging after making the changes.Then reconnect and do the double lock and sit for 8? If not connect the charger at the battery or under the hood at the jump posts while leaving it connected.
I have to tell you, that if you own a Ford you must have Forscan. It gives you the ability to change and or fix and correct many functions. This is my second Ford. Last one was 40 years ago. I am again disappointed and this will be the last. Quality?
As I mentioned - everyone else I've seen that posted making this Forscan change seems to have also swapped battery to AGM and/or removed fuse for modem - at the same time.
So hardly a proper experiment showing it was just this variable that gave the success they saw.
Because for awhile now - it seems to be known this setting is not actually for the hybrid.
https://www.mavericktruckclub.com/f...y-charge-percentage-setting.53991/post-920394
| Adjust Battery Target State of Charge (Ecoboost only) | BCM | (EZ) Change "Battery Target State of Charge" to desired value (% percent) | Factory = 80% , suggested change 95% (RESET BMS AFTER) |
While you are getting into Forscan - you can search for other PIDs like Auto start stop and find settings that obviously don't apply to the hybrid - but they are there. And even some settings regarding a 2nd 12V battery - which obviously don't apply to the Maverick at all.
So all kinds of orphaned settings and PID readings that don't apply.
Like those I mentioned regarding the battery stats - the manual says for the EB version that stats should be changed if different battery is used. So those are likely for the EB only.
Charging can be on the posts, disconnected doesn't matter unless your charger says it'll do something special if not in-vehicle (like high voltage zaps for extra de-sulf has been claimed).
Truck only logs Amp hours charged when key is on - otherwise it uses the BMS Relearn to discern full charged battery. You can do the BS Reset routine too - but that did nothing for mine except Zero those PID values I gave above, I'd skip it since still the age in days is useful.
So yes to remove charger before you lock for 9-10 hrs.
(I say more than 8, because manual says 8 hrs in sleep mode - which occurs max 75 min after door closes/locks)
You are in a 24MY like me - I've not see the double-lock change anything on ours for lights, I think we got a software change already. Didn't help much frankly.
