Ford Hitch or Curt?
FordTough
Han
Asheville
2023 Maverick Hybrid
I have my $210 worth of points for buying the truck and hooking up Ford Connect. So I can buy the Ford hitch for about $130 using the points. The Curt is like $230. Does anyone know of a reason I shouldn't buy the Ford hitch? Is it harder to install? Lower quality? All the accessories seem overpriced to me so I may as well use my points on something I actually need.
OleFordGuy
strictly assuming here....i would guess the quality, etc of them both are very similar (good). Seems to me, the more important item would be the wiring harness. I seem to recall a lot of post about some causes issues, maybe that worked out now, i don't know, but you may want to research/read up on that imo. Maybe others can provide better info/feedback. Good Luck
FordTough
FordTough
Han
Asheville
Thanks for the reply.
On Uhaul's site when you select the Curt trailer hitch for install they have a Curt 4 pin that goes with it
Part number: CMF59236 $69
Ford sells a 4 pin for the Maverick for $125
I know the Curt hooks up to the taillight. I'm assuming Ford would as well. Both seem high for a few wires and a plug but in any case I think that's sorted for 2023.
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
It's more than just wires hooking up to the tail lights. There is an actual computer module that interfaces with the truck. When you plug something into it it will detect it and let you know if there is something wrong with the trailer lights. This is the cause of the constraint on the trailer hitch receivers.
lonwright
Lon
Tallahassee, Fl
Have ordered a Maverick hybred
I just finished installing the Curt wiring harness, purchased thru the NAPA site, I couldn't find it on Amazon. It was pretty easy to install though it took me a lot longer than the time they said it would take. Just plug and go with everything except the wire to the battery. There is a good video on youtube for the installation. Pricy.
A51Mav
Jerry
Maverick XL
I bought and installed the Curt hitch. I did a lot of research on the Ford and Curt hitch. There are videos for both installations on you tube. The Curt is an easier installation. The Ford hitch requires removing the bumper cover, etc.
I think the Ford hitch has a little higher tow capacity, but I didn’t feel it was worth the extra work. I also bought the etrailer wire harness. It’s plug and play. The hardest part is running the power wire to the battery.
Wylie61
West Columbia, SC
2023 Lariat Hybrid
Bought the ford oem Ford requires removal of bumper, not sure about curt. Install took about 2 hours. Used curt wiring, Curt is plug and play, just need to wire to power. Believe ford requires splicing into wires.
Xbbqpitmaster
Full Time Gypsy
2024 Ford Maverick XLT
Ford does not make the hitches. They come from a supplier, possibly Curt or one of the others. You will have to also get the wiring module like others have said.
Skifletch
Buffalo
2023 Maverick XL
How long are you gonna keep the vehicle? In North Carolina it probably won't matter. In one of the road salt capitals of the country I live in (Buffalo) the Curt ones SUCK. They're just piles of rust in 3 years. I've used them on many different vehicles. Their paint/coatings are putrid in my experience. Others may have better luck, I do not.
I put the Ford one on mine
TheWizziard
Texas-RGV
The Curt and Ford wiring harness are similar in the number and locations of the connections you have to make. With the ford you have to splice the wires and the Curt has plug-in adapters for in each trail light. I have the ford harness. The most time consuming for both is running the positive to the battery. Under the hood in the EcoBoost and under the rear seat for the hybrid.
etrailer has a video showing how to run the positive under the hood
U-Hual has a video showing how to run the positive to the rear seat.
I have Curt receiver on order. Only because it was less expensive than the Ford OEM
The Ford OEM receiver does require the removal of the bumper cover. Which I have done already for a different project. It takes some time but it is not difficult.
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
When I added my hitch I could not find for sure if the hitch ordered through ford accessories is the same as the production hitch. The production hitch as mentioned already requires bumper cover removal, which can be tedious. The Curt does not, and is really pretty easy to install. Downside to Curt is that it will not work with the full size spare. I went with the Curt.
markinvictoria
2023 Maverick XLT
I went with the Curt...and it does work with the full size spare...you just have to drop the spare while installing the hitch...no big deal...just crank it down while installing and then crank it back up. Still trying to figure out what to do for a wiring harness.
TheWizziard
Texas-RGV
I have a Hybrid
I put the module and most of the wiring in the left rear taillight.
I originally connected the positive to the positive of the left side 12v bed connector
I ran the wire for the right light along the crash bar to the right tail light.
I installed a 110vac wire from the back of the rear seat through a rubber boot next the the battery to the passenger side cubby. While I did this I also ran a new 12v wire from the battery along the right side of the Maverick then to the left tail light along the crash bar. I changed the tail light module to this wire. Fused at the battery
